FUNCTION MATRIX ADR SHEET
FUNCTION MATRIX ADR SHEET - Need help manipulating the matrix - Messages
#1 Posted: 1/9/2021 7:19:46 PM
Ruben Sidranski
Ruben Sidranski
17 likes in 465 posts.
Some direction would be appreciated. This is a function I created and I got it to work straight up; however, I am trying to eventually generate the table (visual cue) and "cherry-pick" the value used in calculations. The values are coming into the matrix, but I'm stuck being required to input the argument as a vector/matrix.ADR.sm (127.5 KiB) downloaded 990 time(s).
Thank you
#2 Posted: 1/9/2021 10:34:24 PM
Quick brute force for a range of values, AFAIU.
Cheers old Collab Elsid ... Jean
ADR brute force.sm (150.39 KiB) downloaded 1006 time(s).
#3 Posted: 1/10/2021 1:02:58 AM
... here is a more complete search.
ADR brute force augmented.sm (159.59 KiB) downloaded 979 time(s).
#4 Posted: 1/10/2021 9:17:49 PM
Don't miss the Truth Table Companion in Samples.
#5 Posted: 1/10/2021 11:16:00 PM
598 likes in 1,379 posts.
Aaah now I get what you meant.
This should solve your problem.
Deleted previous post.
#6 Posted: 1/11/2021 12:56:03 PM
Ruben Sidranski
Ruben Sidranski
Is this using the Maxima Plugin? Yes, this is what I was looking to do. I started playing with the Maxima "Solve" feature giving me indigestion. Thank you
#7 Posted: 1/11/2021 1:25:58 PM
InterpBilinear() is in the 'Custom Functions' plugin.
Basically an interpolation with two variable.
Good and useful function.
#8 Posted: 1/11/2021 2:09:54 PM
... from the attached example,
get inspired to construct the data ready for matrix interpolation.
Elsid Spline Table.sm (19.1 KiB) downloaded 993 time(s).
