Implicit Plot
Implicit Plot - Messages
#1 Posted: 2/19/2018 12:34:45 AM
1,084 likes in 1,760 posts.
Hi. I'm trying to implement this implicit plot. But can't "cut" the lines in the xy plot. Also, any help about speeding the function is welcome.
iplotq.sm (40.7 KiB) downloaded 1276 time(s).
#2 Posted: 2/19/2018 4:35:55 AM
Fridel Selitsky
Fridel Selitsky
520 likes in 451 posts.
Try the method of Draghilev
DragilevMet.sm (24.09 KiB) downloaded 877 time(s).
#3 Posted: 2/19/2018 6:07:23 AM
Hi Ber. Thanks for the implementation. But it use maple and is semisymbolic, I want just some that can works in the cloud, like: https://en.smath.info/cloud/sheet/s23Pa6bZUn
#4 Posted: 2/19/2018 6:38:09 AM
Fridel Selitsky
Fridel Selitsky
Option without Maple
DragilevMet1.sm (21.62 KiB) downloaded 900 time(s).
frapuano 2/19/2018 7:15:00 AM
#5 Posted: 2/19/2018 7:13:37 AM
Perfect! Thanks.
#6 Posted: 2/19/2018 7:22:41 PM
CBG
CBG
78 likes in 312 posts.
Not graphic
It does not show any error
Carlos
#7 Posted: 2/19/2018 9:28:12 PM
Hi Carlos
For see the error message type B1=
#8 Posted: 2/19/2018 11:44:57 PM
CBG
CBG
Hello Alvaro:
Thank you very much.
The error in the graph is that x is not defined.
What causes this error?
In the graphs published by you it is seen that graphs correctly.
Carlos
#9 Posted: 2/22/2018 3:11:16 AM
Hola Carlos. Try the following, a short version, just for n=2.
DragilevMet2.sm (12.74 KiB) downloaded 886 time(s).
Fridel Selitsky 2/22/2018 4:44:00 AM
#10 Posted: 2/22/2018 4:21:24 AM
Fridel Selitsky
Fridel Selitsky
Try also the old version of the Draghilev method
DragilevMet3.sm (23.18 KiB) downloaded 853 time(s).
Razonar,thanks for the short code for n = 2
#11 Posted: 2/22/2018 2:45:42 PM
Carlos, Alvaro,
From previous use of Dragilev method, I observed great difficulties
to appropriately start/stop rkfixed. Your example above works fine as is.
For more points with less tentatives in specific cases, the easiest way
is to pass it to the closed shape Hermite suite.
I should revisit some of those examples.
The Esplina AI2000 interpolates as well for closed shapes.
Spline Esplina [AI2000].sm (21.79 KiB) downloaded 700 time(s).
Spline Esplina [Hermite].sm (35.44 KiB) downloaded 696 time(s).
Fridel Selitsky 2/22/2018 3:50:00 PM
#12 Posted: 2/22/2018 3:55:44 PM
CBG
CBG
By--> Razonar
Quote
By--> Ber7
Quote
Try also the old version of the Dragilev method
DragilevMet3.sm (24kb) downloaded 10 time(s)
Hola Alvaro, Hello Ber7,
Thanks for your reply, but the DragilevMet2 and 3 files do not work.
The file of Ber 7 does not show any error, but by requiring the value
of B1 and B2, it says that "x" is not defined.
Attached drawing of the errors.
Hello Jean, your files worked perfectly.
Carlos
#13 Posted: 2/23/2018 3:19:44 AM
Hola Carlos.
It's because a problem with rkfixed routine in your environment. Try to download this, or use it in the cloud: DM_RK
#14 Posted: 2/23/2018 3:56:57 PM
CBG
CBG
Hola Alvaro:
Gracias por tu respuesta.
Thanks for your answer, but I found the fault.
The interference is caused by the Maxima Plugin,
by disabling it, the file works correctly.
Carlos
#15 Posted: 2/23/2018 11:30:39 PM
CBG
CBG
Hola Alvaro
Here too, the problem is caused by the decimal separator "Point",
Changing in options, the decimal separator from "Point" to "Comma", (from "." To ",")
resolves the problem of graphing
Carlos
Alvaro 2/24/2018 6:48:00 PM
