CTRL+drag and CustomRegions
CTRL+drag and CustomRegions - Messages
#1 Posted: 8/1/2013 9:48:30 AM
1,442 likes in 2,935 posts.
Some issues when copying CustomRegions (like built-in 2D plots) with CTRL+drag:
- when the description is enabled cause an oversized selection of the output; if the base region have a description and is disabled, some glitches appears
- if you select the original region and you change the font size, the clone have the same font-size of the original (CTRL+V display the output with the correct font-size)
best regards,
Davide
MOVED IN THE BUG TRACKER
#2 Posted: 8/1/2013 7:09:40 PM
2,335 likes in 4,033 posts.
Thank you! I'll check it.
