Units problem with exponential
Units problem with exponential - Messages
#1 Posted: 10/17/2023 5:29:01 PM
juhiimi
juhiimi
0 likes in 4 posts.
Hello!
Please see the attachment. Why is this happening? I need my results in Newton or KNewton.
Can you help me identify the problem here?
Thank you!
#2 Posted: 10/17/2023 6:13:36 PM
1,436 likes in 2,916 posts.
This happens because you are facing an experimental formula with implicit units.
Here, as per definition, f.ck must be entered in [MPa], B and H in [mm], and then the result is returned in [N]; if you do a dimensional analysis, this could work only because the "magic numbers" 100 and/or 0.12 have implicit units.
To make it work in SMath, you have to divide f.ck by the expected input unit and multiply the formula for the expected output unit.
#3 Posted: 10/17/2023 7:22:32 PM
juhiimi
juhiimi
0 likes in 4 posts.
Thank you very much!
P.S. If I multiply it by N/mm2 I get the N result because of the B and H being in mm.
#4 Posted: 10/17/2023 9:04:40 PM
Yes, sorry, obviously B and H are inputs with units too
