DISCARDED: SMath Studio 0.99.6647 (14 March 2018)
DISCARDED: SMath Studio 0.99.6647 (14 March 2018) - Messages
#1 Posted: 3/13/2018 2:25:12 PM
2,318 likes in 3,997 posts.
List of changes (between 0.99.6646 and 0.99.6647 versions)
Improvements
  • Support for Shift+Enter keystroke (in addition to Ctrl+Enter) added for equations breaking;
  • F11 keystroke handles Step In functionality now;
  • Close button added to Debugging/Output panels;
  • SS-2322: Ctl+A keystroke enabled into Output window.
Corrections
  • Displayed error occurred on incorrect break/continue usage fixed;
  • Rendering of range(..) functions corrected;
  • Slow performance of el(..) function in some cases when working with complex numeric expressions fixed;
  • Inserting 'i' char after apostrophe symbol or as a first function's name letter fixed;
  • SS-3511: Rendering of boolean equal operator improved;
  • Result matrix resize symbols made agnostic to fonts available on the machine;
  • Symbolic engine error causes evaluation abort fixed;
  • Refactoring of the Calculation logic in a separate system thread performed (errors related to manual termination of the evaluation fixed);
  • Mouse wheel handling by regions in Pages View mode fixed (it was impossible to use mouse wheel over some parts of the focused region);
  • Replacing of function existing on the worksheet with another one using Dynamic Assistance list fixed;
  • Select All (or Ctrl+A) inside a Worksheet allowed now when Calculation is in progress;
  • Loading of the program became faster on some environment configurations.
Miscellaneous
  • Errors handling logic reworked;
  • Refactoring.
Download
SMathStudioDesktop.0_99_6647.Mono.tar.gz (1.28 MiB) downloaded 1744 time(s).
SMathStudioDesktop.0_99_6647.Setup.msi (2.15 MiB) downloaded 3491 time(s).
SMathStudio 0.99.6646 and 0.99.6647 discarded due to serious bug with colapsed areas, which could damage your worksheet data.
Sorry for inconvenience. Working to fix it asap!
10 users liked this post
Василий Николаевич Храмушин 3/13/2018 2:43:00 PM, Arie 3/13/2018 2:44:00 PM, uncblue 3/13/2018 3:00:00 PM, sergio 3/13/2018 3:41:00 PM, Igor Skarine 3/13/2018 5:33:00 PM, frapuano 3/13/2018 8:08:00 PM, Вячеслав Мезенцев 3/13/2018 11:59:00 PM, NDTM Amarasekera 3/14/2018 1:39:00 AM, Radovan Omorjan 3/14/2018 4:00:00 AM, Davide Carpi 3/14/2018 9:04:00 AM
#2 Posted: 3/13/2018 2:42:01 PM
Arie
Arie
94 likes in 285 posts.
uMath Files Plugin appears to be broken with new release.
#3 Posted: 3/13/2018 2:58:12 PM
Thank you! Fixed and new plug-in version uploaded.
#4 Posted: 3/14/2018 12:53:10 PM
Updated version released: SMath Studio 0.99.6647.
#5 Posted: 3/14/2018 1:18:53 PM
1,344 likes in 2,258 posts.
The result formatting options of math regions aren't saved or handled correctly, see SS-3515.
#6 Posted: 3/14/2018 1:48:34 PM
Jason McCool
Jason McCool
9 likes in 78 posts.
Area controls seem to have been adversely affected with this build. A worksheet I have where a lot of the calcs are hidden inside separate areas to allow for the option of a "summary" calc or a "detailed" calc opened up almost completely unreadable. It appears the contents of the collapsed areas are being displayed over the top of each other all in 1 line instead of being hidden inside the area. See the attached screenshot. Also experiencing some instability when trying to click on the area "+" signs to expand them. The areas don't expand, and instead completely disappeared once. Deleting one area at the end of the worksheet deleted all the calcs (4 pages with all areas collapsed, 10 or so pages fully expanded) except for the part that had been inside the first collapsed area on the first page.
Thanks,
Jason
Davide Carpi 3/14/2018 1:53:00 PM
#7 Posted: 3/14/2018 2:10:28 PM
Please could you send a file to me by e-mail to fix? I cannot reproduce this issue on any of my worksheets.
#8 Posted: 3/14/2018 4:24:20 PM
120 likes in 337 posts.
I experienced problems similar to those of Jason.
In my case, when the sheet is opened, the problem does not exist but after saving the sheet, after closing it and finally reopening, problems with the collapsed areas occur.
#9 Posted: 3/14/2018 4:25:20 PM
Jason McCool
Jason McCool
Sorry, I forgot to check to get responses by email when I posted earlier. Here you go
C6 Channel Shear Tab.sm (228.91 KiB) downloaded 1152 time(s).
#10 Posted: 3/14/2018 4:31:45 PM
Jason, I see this file was saved by SMath Studio 0.99.6646.16669 and already have problems.
Do you have the initial version?
#11 Posted: 3/14/2018 4:33:56 PM
Sergio, seems this is very important issue. And bug is in saving logic.
Please could you provide any file which gives this error on save?
Thanks in advance!
#12 Posted: 3/14/2018 4:46:23 PM
Jason McCool
Jason McCool
I actually hadn't meant to be using beta versions on my production work, but I apparently unchecked the "exclude beta versions" at some point recently and had saved that worksheet in build 6646. It seemed to work well yesterday, and I have a pdf printout that doesn't show any issues with the display of the collapsed areas, but that was printed to pdf prior to saving and closing, so perhaps it is the same behavior as for Sergio. I had to finish getting some calcs ready for a client today, so I reinstalled the last stable build from the website this afternoon, and can't confirm the behavior now with any of the beta builds. But here is the original worksheet that works in build 6622. Thanks!
Jason
Channel Shear Tab.sm (228.88 KiB) downloaded 1138 time(s).
#13 Posted: 3/14/2018 4:46:36 PM
Thank you Jason and Sergio!
I've reproduced this issue and it is introduced exactly in 0.99.6646.
I'm working to figure out the reason and fix it asap.
The following SMath Studio nightly builds are marked as NOT APPROVED and will not be suggested to download to anyone anymore: 0.99.6646, 0.99.6647!
Show Spoiler
Thank you very much for the report and your help!
Jason McCool 3/14/2018 4:48:00 PM
#14 Posted: 3/14/2018 4:52:50 PM
prova1.sm (2.87 KiB) downloaded 1133 time(s).
it's a trivial file. When I saved it, it appeared correctly but if I open it, the error occurs on the collapsed area
