Thiele Function Automation
Thiele Function Automation - Automation of the Thiele function - Messages
#1 Posted: 4/30/2018 5:45:46 PM
CBG
CBG
78 likes in 312 posts.
This example is an automation of the Thiele function
published by Jean in the "Utilities Pts logpts Application" sheet
Thiele_Automatic_Jean_cbg.sm (22.08 KiB) downloaded 1055 time(s).
Carlos
#2 Posted: 5/1/2018 7:33:59 PM
... refreshed a bit, a note added.
Superb, the piece of automated interpolation.
Thanks Carlos ... Jean
Thiele_Automatic_Jean_cbg.sm (26.85 KiB) downloaded 1072 time(s).
#3 Posted: 5/2/2018 6:23:05 PM
CBG
CBG
Hello Jean,
Please review the following example that you posted.
Thiele Model Construct.sm (44.15 KiB) downloaded 1077 time(s).
Thank you
Carlos
#4 Posted: 5/3/2018 10:37:19 AM
Hello Jean,
Hello Carlos,
The attached document has been doctored.
The long native form is as nice to export than the reduced J_Frac.
J_Frac is more compact, but not as clear for unfamiliar user.
Thiele is capricious wrt to Maple [see the blue note].
It starts refusing if too many Maple instances have been invoked,
maybe a limited courtesy from Maplesoft ?
Please let me know if correct in your Smath system.
See you soon ... Jean
From fresh Smath session, supports the 3 documents attached.
Thiele_0 Demo.sm (57.41 KiB) downloaded 1042 time(s).
Thiele Transit_Convert.sm (13.57 KiB) downloaded 1060 time(s).
Thiele Model Construct Copy.sm (37.77 KiB) downloaded 1063 time(s).
#5 Posted: 5/9/2018 6:39:36 PM
CBG
CBG
Hello Jean
Updated version of Interpolation using the Thiele algorithm in cuntinuous fractions.
It includes the calculation of the inverse differences φ [x0, ..., xi], obtained from the values in the known points
Rounding the values of the inverse differences for the purpose of presenting the equation to make it shorter
Thiele_Automatic_Jean_CBG_R1.sm (69.59 KiB) downloaded 1101 time(s).
Carlos
#6 Posted: 5/10/2018 10:37:06 AM
Hello Carlos,
What a delicious/educative/Engineering piece of work ... zillions thanks !
Reshaped a bit for first time readers.
Thiele_3 Automatic [on error Carlos].sm (36.97 KiB) downloaded 861 time(s).
