using lookup function not work in sqrt command
using lookup function not work in sqrt command - Messages
#1 Posted: 5/17/2012 6:10:08 AM
xyonx
xyonx
0 likes in 10 posts.
hi all,
i try using lookup function descirebed by admin, however it's not work in using sqrt commands.
none
what a poblem? anybody can help?
thx u
#2 Posted: 5/18/2012 2:27:35 AM
The problem is that "x" variable is a matrix with single element - pay attention on the brackets. Therefore, square root of a matrix is not defined in SMath.
Try this:
[MATH=eng]x:mat(6,1,1)[/MATH]
[MATH=eng]sqrt(el(x,1))=2.4495[/MATH]
#3 Posted: 5/18/2012 8:28:56 AM
xyonx
xyonx
hi,
when using lookup function the bracket are in matrix mode by default
none
i can not using these extracted data from lookup function to make further calculation using sqrt commands
thx u
#4 Posted: 5/18/2012 8:52:51 AM
1,438 likes in 2,923 posts.
there are two errors
here is the file in the image: vlookup_debug.zip
regards,
w3b5urf3r
#5 Posted: 5/19/2012 3:45:17 PM
xyonx
xyonx
Quote
use the "[" after typing "x" to add the vector index
thx u for clearly explains the typing method in previously posted by Ommor, it cut down my times and complexity using too much multiple branch
