Error while saving
Error while saving - Messages
#1 Posted: 6/11/2015 9:04:25 AM
Werner Beek
Werner Beek
0 likes in 2 posts.
Dear all,
Daily I'm working on my smath file. Since the latest changes I get the following error while saving:
"Unexpected end of file has occurred. The following elements are not closed: input, math, region, region, region, region, regions. Line 35237, position 18."
The programm closes and the saved file cannot be opened any more. Does anyone know a solution?
Thanking you in advance,
Werner
#2 Posted: 6/11/2015 8:11:39 PM
1,438 likes in 2,920 posts.
You can (partially) fix the file by closing the missing xml tags (using a text editor).
To find the cause and fix the issue a reproducible sequence of actions or the file is needed (you may contact directly the developper if the file can't be shared here)
ioan92 6/12/2015 4:08:00 AM
#3 Posted: 6/12/2015 4:02:49 AM
Hello Davide,
Is there any way that someone can write a Recovery script which will fix the broken SMath file. I remember that I found long time ago some similar script for the corrupted Mathcad files.
ioan92 6/12/2015 4:08:00 AM, Davide Carpi 6/12/2015 7:54:00 AM
#4 Posted: 6/12/2015 7:49:13 AM
I think is possible. Tomorrow I'll try to do something.
Radovan Omorjan 6/12/2015 8:11:00 AM, ioan92 6/12/2015 8:20:00 AM
#5 Posted: 6/17/2015 7:16:14 AM
Werner Beek
Werner Beek
0 likes in 2 posts.
Dear all,
I installed the latest nightly build version of Smath and since then I cannot reproduce the error any more.
