X-Y Plot for electrical resistance
X-Y Plot for electrical resistance - Trying to plot electrical resistance - Messages
#1 Posted: 10/16/2021 6:56:17 PM
Fabian
Fabian
0 likes in 3 posts.
I am trying to plot electrical resistance using Electrical Engineering Library and X-Y-Plots Plugins but it does not seem to work:
Can anyone help me plot this?
#2 Posted: 10/16/2021 7:41:28 PM
598 likes in 1,379 posts.
Delete the ohm unit in Rp.
Usually you shouldn't use units while plotting.
For information, this includes most numeric solver functions too.
#3 Posted: 10/16/2021 7:46:20 PM
Or if you will really need units;
Try to eliminate or add them in the input data.
It is to avoid them being used in plot.
Or to avoid conflict between unit-ed numbers and not unit-ed.
When you use Rx in your function, it can't be EEL_par with 1 ohm.
Plot try to use Rx as an number not a unit added number.
You either add unit to Rx or do opposite.
Opposite is eliminating all units of other variables.
#4 Posted: 10/17/2021 1:03:39 PM
Fabian
Fabian
0 likes in 3 posts.
Thanks, this makes total sense.
Also, how is it possible to only plot (or "stem" as it is called in Matlab ) integer values?
#5 Posted: 10/17/2021 2:28:23 PM
Maybe I chose a wrong word to describe it, shall edit.
It will plot not only integers, numbers actually.
But plot expect them to be dimensionless.
Not just X-Y plot, built-in 2D plot also.
#6 Posted: 10/17/2021 4:08:04 PM
Fabian
Fabian
0 likes in 3 posts.
Plot try to use Rx as an integer not a unit added number.
So how did you add the Ohm symbol under the plot? It won't let me add a unit there.
#7 Posted: 10/17/2021 4:23:47 PM
1 - Hit multiply after Rx;
2 - (Type W in place holder, place Ctrl+G) or (Click ohm from right pane);
3 - Placeholder shall appear, either double click or press tab to insert Ω as unit.
If you are not typing units after numbers, this is the way.
You can also type ' between step1 and step2.
Units can be typed or chosed with this way more quick.
This will directly open placeholder scroll menu.
#8 Posted: 10/18/2021 7:03:57 AM
Altitude is plotted integers.
Solve INVERSE Recursive NASA.sm (13.76 KiB) downloaded 994 time(s).
#9 Posted: 10/18/2021 9:30:30 AM
... refreshed version ½ timing.
Solve INVERSE Recursive NASA.sm (16.45 KiB) downloaded 1000 time(s).
#10 Posted: 10/18/2021 5:05:53 PM
I don't know if there is a stem equivalent for smath plots.
But you can create your own function for that purpose.
stem.sm (8.62 KiB) downloaded 1011 time(s).
#11 Posted: 10/18/2021 9:03:39 PM
... you can animate the stem system, have symbols too.
Here, integers are the X direction.
Eventually, easy for the Y direction as applicable.
2D Util Stem ANIM Laplace Diffusion.sm (21.6 KiB) downloaded 1068 time(s).
#12 Posted: 10/19/2021 12:42:00 AM
1,118 likes in 1,794 posts.
Hi. In addition to the overlord solution, this is another approach.
stem.sm (12.15 KiB) downloaded 997 time(s).
#13 Posted: 10/19/2021 10:20:17 AM
You can highlight some particular point(s) with glyphe(s) of you choice.
You will have to dispose their position by hand.
2D Plot Setup Glyphes.sm (28.77 KiB) downloaded 959 time(s).
#14 Posted: 10/19/2021 11:19:27 AM
...In addition to the overlord solution...
Mine was not a solution to be honest.
Just a quick and ugly way to show it is possible.
This is a good solution though.
