Link with CAD programs
Link with CAD programs - Link Calculations to FreeCAD or LibreCAD - Messages
#1 Posted: 11/6/2013 3:23:43 PM
Ruben Sidranski
Ruben Sidranski
17 likes in 465 posts.
Way back in MAthCADs tenure (ca MathCAD 8) there was a way of linking drawings (Smartsketch) to your calculations. Is there a way of doing this in SMath? I think FreeCAD may be a possibility as it allows for Python programming and it's 3D (Parametric ). I like LibreCAD (2D ), because I can get it as a portable app. Comments, suggestions?
#2 Posted: 11/6/2013 4:51:19 PM
1,353 likes in 2,265 posts.
Some CAD programs (e.g. Autodesk Inventor) can be driven by parameters in excel sheets. There is good excel connectivity by means of the XLSX Import/Export plugin by Davide Carpi.
Also, SMath seems to have a 2D drawing region which can be driven by calculation results, see here. You also might try the Constructor region (available in the SVN server. This plugin has been updated recently by Andrey. I did not compile or test this, however. But may be, this will become part of the next SMath release.
ElSid 11/6/2013 5:01:00 PM
#3 Posted: 11/6/2013 5:01:58 PM
Ruben Sidranski
Ruben Sidranski
Martin,
Your PM box is full. Where is the link to the SVN server. I cannot find it
#4 Posted: 11/6/2013 5:11:47 PM
The repository is here. I use TortoiseSVN to browse it.
#5 Posted: 11/6/2013 5:11:51 PM
1,442 likes in 2,935 posts.
Click on the Code button on the top of the forum...
constructor region sources
BTW as you can see in the plugin gallery, this plugin actually is not available, so use it (if this is possible) with caution (f.e. not for productivity purposes)
