Стабильная: SMath Studio 1.3.0.9126 (03 февраля 2025) - Messages
Changes introduced in current build 1.3.0.9126
Improvements
- Suggestions logic is implemented to help users to use previously built-in File Type plug-ins moved outside of the standard software distribution package;
- Page Setup dialog improved to allow selecting available substitutions from the dropdown lists for header and footer;
- The non-SI nit unit of measurement added to the Luminance dimension;
- Icelandic interface transation added.
Corrections
- Issue happened when the fractions setting is set to Auto (the result formatting lost the denominator) is fixed;
- Using of the same symbol both for Boolean "exclusive or" and for Money unit symbol is fixed;
- Using of the "greater than" and "lower than" characters fixed in text regions;
- Ability to create several empty worksheets in the program UI by pressing New button restored;
- Fixed rendering issue: support for drawing the opened SVG paths restored;
- Misspelling corrected in translation to Russian.
Miscellaneous
- Default value of the Approximate Equal operators accuracy set to 3;
- The application launch speed has been increased;
- Insert Unit dialog improved to display long titles of the units of measurements;
- Translations improved in the Print Preview dialog;
- All Files option removed from the filter of the Open File Dialog as it has no sense;
- Interface translations updated.
Download
SMathStudioDesktop.1_3_0_9126.Mono.tar.gz (2.17 MiB) downloaded 24195 time(s).
SMathStudioDesktop.1_3_0_9126.Mono.x86_64.astra-orel.glibc2.24.AppImage (10.18 MiB) downloaded 9886 time(s).
SMathStudioDesktop.1_3_0_9126.Setup.msi (3.35 MiB) downloaded 295583 time(s).
SMathStudioDesktop.1_3_0_9126.x86_64.ubuntu-22_04.glibc2.35.AppImage (12.65 MiB) downloaded 19416 time(s).
