Bottles works
Bottles works - Tried many approaches to run the SMathStudio finally found a simple solution - Messages
#1 Posted: 5/28/2026 4:29:45 PM
Tom S
Tom S
0 likes in 5 posts.
It as been a long road to find something that actually worked. I installed Zorin OS 18.1. Downloaded the SMathStudio ... .appImage, if failed to launch
The forum suggest down loading SMathStudio ... .tar,gz and expand it to create a momo folder. A procedure suggested to use was years old and the programs told to use were way out of date and not even available.
I have a windows pc also which had no problem installing SMathStudio ... .msi
The wine that match Zorin OS 18. Failed when running SMathStudio ... .msi giving a problem with NET version.
What does work is Bottles that match Zorin OS 18. Ran SMathStudio ... .msi with the starting page on the screen.
#2 Posted: 5/28/2026 4:42:41 PM
598 likes in 1,380 posts.
Actually problem is Mono installation of all debain (or ubuntu) based distros.
It is broken for nearly two decades, and there is no fix of I know.
Only proper way to correct this is manual reinstallation of Mono.
Try to do what I had done in this reply, pretty sure SMath will run.
In fact, this will fix Mono for all c# programs using it.
https://smath.com/en-US/forum/topic/QGuTDE/Cannot-run-in-Ubuntu-22_04#msg143067
