[MONO] SMath 99-6611 Hangs the system
[MONO] SMath 99-6611 Hangs the system - Messages
#1 Posted: 2/9/2018 4:57:21 AM
Evgenij
Evgenij
1 likes in 8 posts.
After I'v added "Text region utilities" it worked a little. But on next startups it begin to get into Plug-ins failed to strart" with the above plugin reported. And after I close the dialog and open "Tools -> Plugins... -> On-line gallery" system (Ubuntu Mate 16.04) hangs.
Also I couldn't reset SMath that the error stop appearing.
#2 Posted: 2/9/2018 9:15:45 AM
1,442 likes in 2,935 posts.
Thank you for reporting, I'll check if I can reproduce ASAP. The problem might be with the linking with WriterRegion.
However in the meanwhile you can go in ~/.config/SMath or in ~/.SMath (depending on your OS) and in extensions/plugins manually delete the folder a9f5e37d-83f5-4a4b-a106-0ba7b202abbb (text region utilities)
Evgenij 2/10/2018 8:35:00 AM
#3 Posted: 3/1/2018 12:43:25 PM
oftheair
oftheair
0 likes in 5 posts.
I encountered the same problem. However in my case the folder "text region utilities" has a longer number:
a9f5e37d-83f5-4a4b-a106-0ba7b202abbb/0.3.6353.26919. The differences in Bold font.
oftheair
#4 Posted: 3/1/2018 7:00:52 PM
oftheair
oftheair
0 likes in 5 posts.
Before I read the advice of Mr. Carpi I tried a lot of other measures, among others I have removed all plugins. Now it is a mess. Starting Smath results systematically in hanging of the system. I mean that the solution of this problem will be a complete removal followed by a reinstall of SMath. But how to remove SMath completely?
oftheair
#5 Posted: 3/1/2018 7:33:13 PM
0.3.6353.26919 is a sub-folder; in order to clean SS from the plugin you have to delete a9f5e37d-83f5-4a4b-a106-0ba7b202abbb and all his content
What plugins have you deleted? Those in the executable folder? These shouldn't be never touched; In this case simply download another smath studio package for Linux and delete the old one.
Full cleaning can be reached deleting all the content of the ~/.config/SMath directory (SMath folder and all his content; a new one will be created if you start again SMath Studio)
#6 Posted: 3/1/2018 8:55:42 PM
No procedure has been reported, from recollection.
Similarly to evaporate Mathcad and in order:
1. Add/Remove program ... delete Smath
2. From the Program File directory ... delete Smath
3. from regedit.exe ... delete all Smath entries from any/all registries
4. I have no proof it evaporates Smath completely.
Re-download Smath. Install but before installing, better download
all the plugins, then install, then activate from the gallery menu.
You should have a bran new Smath of the version you just have downloaded.
The "evaporate procedure", install new is dramatically missing
from the main web page about Smath.
