How can I use not a for but a while cycle?
How can I use not a for but a while cycle? - Сообщения
#1 Опубликовано: 09.02.2024 21:27:16
Valery Ochkov
Valery Ochkov
55 сообщений из 633 понравились пользователям.
See please the attached file.Newton.sm (23 КиБ) скачан 59 раз(а).
#2 Опубликовано: 09.02.2024 23:38:00
⚜ Kenny Lemens, P.E. ᵂᴵ
74 сообщений из 164 понравились пользователям.
Greetings,
Instead of using for(3); you can use for(4):
for ▮, ▮, ▮
The four parameter 「for(4)」 gives you the ability to loop while checking a condition. Below is the description of for( {0}, {1}, {2}, {3} )
"For loop. The function of controlled iterations. The cycle repeats {3}, while {0} satisfies the condition {1} and after each passage necessarily satisfied {2}. Repeating expressions can be set to any number of expressions."
example:
for i:=1, i<10, i:=i+2
   k:=2*i
Where 'i' starts at 1 and until i is no longer less than 10, perform operation of k:=2*i. Apply operation i:=i+2 and check if less then 10...; LOOP!
May this be of Good Help;
Valery Ochkov 10.02.2024 14:37:00
#3 Опубликовано: 10.02.2024 14:38:31
Valery Ochkov
Valery Ochkov
Thanks
But see "???" in the attach
Newton-for-1-2-3-4.sm (26 КиБ) скачан 59 раз(а).
#4 Опубликовано: 10.02.2024 18:38:42
StvMath
StvMath
35 сообщений из 56 понравились пользователям.
Here's a "while" version
Newton-for-1-2-3-4_b.sm (18 КиБ) скачан 53 раз(а).
Valery Ochkov 10.02.2024 19:44:00
#5 Опубликовано: 11.02.2024 01:58:11
As well, while associates with Bolean Critical region
Solve [Dichotomy_Newton_Secant] Copy.sm (52 КиБ) скачан 53 раз(а).
Valery Ochkov 11.02.2024 02:13:00
#6 Опубликовано: 11.02.2024 02:53:28
Valery Ochkov
Valery Ochkov
Roots vs Newton
#7 Опубликовано: 11.02.2024 07:55:50
oots vs Newton
No interest vs the codes
#8 Опубликовано: 11.02.2024 13:41:06
Valery Ochkov
Valery Ochkov
Roots vs Newton
https://www.mdpi.com/2227-7390/10/19/3413
#9 Опубликовано: 11.02.2024 21:59:12
roots solves Matrix.
Worksheet33.sm (6 КиБ) скачан 55 раз(а).
#10 Опубликовано: 13.02.2024 06:19:59
mNewton() from the Maxima plugin is another option. It also may fail for particular initial guess values.
mNewton.sm (16 КиБ) скачан 59 раз(а).
Alvaro Diaz Falconi 29.02.2024 12:13:00
