1 страниц (10 вхождений)
How can I use not a for but a while cycle? - Сообщения
#1 Опубликовано: 09.02.2024 21:27:16
See please the attached file.Newton.sm (23 КиБ) скачан 61 раз(а).
#2 Опубликовано: 09.02.2024 23:38:00
Greetings,
Instead of using for(3); you can use for(4):
The four parameter 「for(4)」 gives you the ability to loop while checking a condition. Below is the description of for( {0}, {1}, {2}, {3} )
example:
Where 'i' starts at 1 and until i is no longer less than 10, perform operation of k:=2*i. Apply operation i:=i+2 and check if less then 10...; LOOP!
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
for ▮, ▮, ▮
"For loop. The function of controlled iterations. The cycle repeats {3}, while {0} satisfies the condition {1} and after each passage necessarily satisfied {2}. Repeating expressions can be set to any number of expressions."
example:
for i:=1, i<10, i:=i+2
k:=2*i
k:=2*i
Valery Ochkov 10.02.2024 14:37:00
#3 Опубликовано: 10.02.2024 14:38:31
#4 Опубликовано: 10.02.2024 18:38:42
Valery Ochkov 10.02.2024 19:44:00
#5 Опубликовано: 11.02.2024 01:58:11
As well, while associates with Bolean Critical region
Solve [Dichotomy_Newton_Secant] Copy.sm (52 КиБ) скачан 56 раз(а).
Valery Ochkov 11.02.2024 02:13:00
#6 Опубликовано: 11.02.2024 02:53:28
#7 Опубликовано: 11.02.2024 07:55:50
Wroteoots vs Newton
No interest vs the codes
#8 Опубликовано: 11.02.2024 13:41:06
#9 Опубликовано: 11.02.2024 21:59:12
#10 Опубликовано: 13.02.2024 06:19:59
mNewton() from the Maxima plugin is another option. It also may fail for particular initial guess values.
mNewton.sm (16 КиБ) скачан 61 раз(а).
Alvaro Diaz Falconi 29.02.2024 12:13:00
Новые сообщения
Нет новых сообщений
