1 страниц (7 вхождений)
Drop down options - Select variable based on the value of another variable - Сообщения
#1 Опубликовано: 30.04.2020 05:32:46
Hi I am new to Smath
I want to select few variables. eg
If P=1, then X = 1, Y=2 & Z=3
If P=2, then X = 4, Y=1 & Z=7
If P=3, then X = 3, Y=2 & Z=1
I want to use X, Y & Z values based on the selected value of P
Thanks in advance
Thanks in advance
#2 Опубликовано: 30.04.2020 08:33:57
#3 Опубликовано: 30.04.2020 08:36:30
Thanks Jean
I will try this one
I will try this one
#4 Опубликовано: 30.04.2020 08:42:33
Davide Carpi 01.05.2020 08:59:00
#5 Опубликовано: 30.04.2020 09:26:22
Davide Carpi 01.05.2020 09:00:00
#6 Опубликовано: 30.04.2020 11:25:14
If you want to use the variable names X,Y,Z
a simple
data:mat(1,4,3,2,1,2,3,7,1,3,3)
mat(X,Y,Z,3,1):col(data,p)
will do the job.
you can also use a vector XYZ
XYZ:el(data,range(1,3),p)
and its components i=1..3
el(XYZ,i)
copy code to sheet
a simple
will do the job.
el(XYZ,i)
copy code to sheet
#7 Опубликовано: 30.04.2020 12:41:19
Generalize demo. No sweat to capture [X,Y,Z] from n*m matrix.
Page5 Generalize.sm (5 КиБ) скачан 59 раз(а).
Новые сообщения
Нет новых сообщений
