1 страниц (14 вхождений)
[X-Y Plot plugin] region dissappears when ploting - Сообщения
#1 Опубликовано: 24.06.2016 19:45:22
#2 Опубликовано: 24.06.2016 21:35:35
Hi Basile. A bug without the file could be hard to interpret.
But, unregarding math or bugs, you're trying to use negative frequencies. Are you sure about what could be represent that? Also, a zero frequency, what is it? Direct current?
Frequencies also are usually represented in a log scale.
#3 Опубликовано: 24.06.2016 22:42:36
#4 Опубликовано: 24.06.2016 23:19:22
Hi Basile. You discover a couple of nice and unwanted visual special effects in blue. I know near nothing about smath plugins, and can't help about them.
#5 Опубликовано: 25.06.2016 00:38:12
Two things Basile:
1. Your unit systen is wrong [L => H, C => F]
2. Xc, XL have nothing to do with an LC circuit.
XL is equal to f(x):= dontknow*x
XC is equal to f(x):= 1/dontknow*x
https://en.wikipedia.org/wiki/LC_circuit
#6 Опубликовано: 25.06.2016 09:38:01
Jean,
My system of units is NOT wrong.
Capacitance in Farad
Inductance in Henry
Reactance of both in Ohm.
Basile
Inductance in Henry
Basile
#7 Опубликовано: 26.06.2016 07:51:00
Seems the issue is related to negative infinity
#8 Опубликовано: 26.06.2016 09:18:34
Basile,
What you did is no not correct: You copied the L
plot and put in it the C plot with the same L scales.
So, the C plot flies in the blue. Someting like this:
If you photograph a mouse and an elephant in the same
bed, you won't see both. If you adjust for elephant,
the mouse will be a dot pretty hard to isolate and
enlarge unless you have zillions of MP resolution ...
#9 Опубликовано: 26.06.2016 09:27:34
#10 Опубликовано: 26.06.2016 14:31:03
Jean,
Yes, it works with the Plot 2D.
The problem is with the X-Y plot. It disappears and freezes the instance of Smath!
As pointed by Davide a possible problem with minus infinity?
Basile
Basile
#11 Опубликовано: 26.06.2016 16:05:08
WroteThe problem is with the X-Y plot. It disappears and freezes the instance of Smath!
NO => Not as you think. X_Y is not an autoplot, it is a plot range.
If you plot sin(x) it falls in its default XY ranges OK. Otherwise
you have to range both directions. X_Y does not supports few things:
1. It does not plot x. It does not understand that 'x' is implicit
of 'x' = "1*x" neither implicit of 'x' = 'x+0'
2. It supports some common Engineering ranges 1*e ±3 [per say]
but will crash Smath instance if you want to range 1*e ± -15
X_Y is lovely in many projects but not in others.
#12 Опубликовано: 29.06.2016 13:02:35
By increasing the limit values of the function the graph does not
pass through a pivotal point
Bug.sm (8 КиБ) скачан 60 раз(а).
#13 Опубликовано: 29.06.2016 14:31:53
WroteBy increasing the limit values of the function
That's right but not a bug. Just that above the Y magnitude 45,
the canvas misses some points in the critial region.
More: does not fill the circle, plots x instead of +
X_Y Plot wisely.sm (11 КиБ) скачан 64 раз(а).
Fridel Selitsky 29.06.2016 14:37:00
#14 Опубликовано: 29.06.2016 14:38:02
Новые сообщения
Нет новых сообщений
