wrong axis labels in plot2d
wrong axis labels in plot2d - Сообщения
#1 Опубликовано: 29.08.2013 13:21:44
1226 сообщений из 2153 понравились пользователям.
In the 2D plot region, I observed a tick label (number) to switch from the correct value (8) to zero for special scaling values. Even if there is XY-Plot region if nice labeling matters, this might be worth a fix.
#2 Опубликовано: 29.08.2013 16:56:21
Hmm...can not reproduce this,
#3 Опубликовано: 29.08.2013 17:52:22
1418 сообщений из 2873 понравились пользователям.
Is not a bug, just an eye-trick due to a combination of font-size, line thickness and line position; if you move the grid or you zoom your page you can see the trick (plot not evaluated)
best regards,
Davide
Martin Kraska 29.08.2013 21:32:00
#4 Опубликовано: 29.08.2013 21:32:11
Thanks for pointing this out. Then the remedy is easy: change the z-order of the objects (grid to bottom). I did not note that the grid is in front of the tick labels.
#5 Опубликовано: 30.08.2013 06:55:02
I agree, should be the easiest solution
