Beam calculation
Beam calculation - Ber7 - Сообщения
#1 Опубликовано: 19.11.2011 16:24:17
Fridel Selitsky
Fridel Selitsky
https://smath.com/wiki/GetFile.aspx?File=Beam.rar
Oscar Campo 19.11.2011 23:33:00
#2 Опубликовано: 20.11.2011 10:51:08
Fridel Selitsky
Fridel Selitsky
https://smath.com/wiki/GetFile.aspx?File=Cantilever.rar
#3 Опубликовано: 20.11.2011 10:51:45
Edward Ulle
Edward Ulle
20 сообщений из 182 понравились пользователям.
Ber7,
You amaze me with your use of graphics in SMath. I'm a civil engineer and use SMath for calculations just like this but without the pictures.
Could you post your SMath sheet in a zip file so I can see how you do it? I don't use RAR. Thanks.
Ed
#4 Опубликовано: 20.11.2011 15:42:36
Fridel Selitsky
Fridel Selitsky
Ed
https://smath.com/wiki/GetFile.aspx?File=Cantileverzip.zip
https://smath.com/wiki/GetFile.aspx?File=Beamzip.zip
#5 Опубликовано: 20.11.2011 16:41:50
Edward Ulle
Edward Ulle
Ber7,
Your animations and drawings always amaze me. Thanks.
Ed
#6 Опубликовано: 21.11.2011 05:38:01
Fridel Selitsky
Fridel Selitsky
https://smath.com/wiki/GetFile.aspx?File=Contin%5d.zip
#7 Опубликовано: 24.11.2011 05:06:47
Fridel Selitsky
Fridel Selitsky
https://smath.com/wiki/GetFile.aspx?File=ElastFound.zip
#8 Опубликовано: 03.04.2012 19:14:42
olik
olik
3 сообщений из 27 понравились пользователям.
Hello.
This is very nice. I am civil ingenieer & I will use it. Thanks.
However it is dangerous to use the function x>Lf.
I found it out in my own beam programming.
When changing direction of concetrated forces, the graph of shearing force has to jump once up & once down.
And for the following input it does not!
It seems to me, the function x>Lf does not work correctly each time.
Regards Olik
SMath files: beam 3 & 4.zip
Fridel Selitsky 04.04.2012 02:12:00, Andrey Ivashov 04.04.2012 02:05:00
#9 Опубликовано: 03.04.2012 19:20:59
kmihaylovich
kmihaylovich
8 сообщений из 131 понравились пользователям.
Olik, try to change x>Lf to eval(x>Lf).
Fridel Selitsky 03.04.2012 22:49:00, olik 04.04.2012 13:55:00
#10 Опубликовано: 03.04.2012 22:52:33
Fridel Selitsky
Fridel Selitsky
Thank you, kmihaylovich, the file is corrected.
Regards,Ber7
#11 Опубликовано: 04.04.2012 02:04:53
Группа: Super Administrator
Thank you! This is already fixed and will work correctly even without eval function into the next SMath Studio release.
Regards.
#12 Опубликовано: 04.04.2012 13:58:31
olik
olik
Thanks to all. The eval function seems to be a good way.
And if You fix this little bug, it will be the best.
Regards, Olik
#13 Опубликовано: 15.01.2013 13:20:31
Fridel Selitsky
Fridel Selitsky
Single moving load
AnimBeam.smz (6 КиБ) скачан 376 раз(а).
Davide Carpi 15.01.2013 14:02:00, Oscar Campo 15.01.2013 15:29:00
#14 Опубликовано: 14.02.2013 11:35:46
Fridel Selitsky
Fridel Selitsky
The load moves in deflection curve
AnimBeam1.smz (6 КиБ) скачан 303 раз(а).
Davide Carpi 14.02.2013 13:40:00
#15 Опубликовано: 20.03.2013 18:20:44
Fridel Selitsky
Fridel Selitsky
Beam on elastic foundation.Movable load
MoveEl.smz (8 КиБ) скачан 325 раз(а).
Davide Carpi 20.03.2013 20:58:00
#16 Опубликовано: 11.06.2013 05:10:10
Fridel Selitsky
Fridel Selitsky
Graphics with shading
(http://en.smath.info/forum/resource.ashx?a=1691)
AnimBeam2.sm (38 КиБ) скачан 321 раз(а).
Вячеслав Мезенцев 11.06.2013 12:00:00, ioan92 11.06.2013 05:58:00, IVR 11.06.2013 12:39:00, Davide Carpi 12.06.2013 19:18:00
#17 Опубликовано: 12.06.2013 11:05:41
Fridel Selitsky
Fridel Selitsky
Cantilever-new edition
https://smath.com/wiki/GetFile.aspx?File=CantileverENExe.rar
CantileverEN.smz (18 КиБ) скачан 345 раз(а).
ioan92 03.07.2013 16:23:00, Davide Carpi 12.06.2013 19:19:00
#18 Опубликовано: 02.07.2013 15:55:17
Fridel Selitsky
Fridel Selitsky
Beam with a variable distance between the supports
BemAnim.smz (15 КиБ) скачан 302 раз(а).
ioan92 03.07.2013 16:23:00, Andrey Ivashov 03.07.2013 17:19:00, Davide Carpi 02.07.2013 16:44:00
#19 Опубликовано: 06.07.2013 14:29:47
Fridel Selitsky
Fridel Selitsky
Analysis of statically indeterminate beam. Supported cantilever.
Beam fixed at the one end supported an the other
https://smath.com/wiki/GetFile.aspx?File=Konsol%2bopora.rar
Konsol+opora.smz (134 КиБ) скачан 381 раз(а).
IVR 07.07.2013 14:46:00, Davide Carpi 06.07.2013 18:31:00
#20 Опубликовано: 11.02.2021 03:32:36
Egidijus
Egidijus
Hello, could somebody help me. I don't understand how to solwe this problem.
