Procedural variables
Procedural variables - Сообщения
#1 Опубликовано: 06.07.2023 23:12:48
Lupus the Canine
Lupus the Canine
Is it possible to procedurally define variables from strings?
I want to load data to a lot of sets of variables with names following a pattern preferably without doing that manually.
Is there a better way than:
example.sm (4 КиБ) скачан 56 раз(а).?
#2 Опубликовано: 07.07.2023 05:06:15
That's one of the other options.
#3 Опубликовано: 07.07.2023 16:18:37
Lupus the Canine
Lupus the Canine
Thanks, unfortunately value to be assigned is supposed to come from somewhere else, z was just an example because I didn't want to make example with large vectors or matrices to be assigned.
I was looking for a function that would turn a string into a variable that can be used as lhs operand in assignment.
#4 Опубликовано: 07.07.2023 20:02:53
If the value to be assigned is an ordinary expression, then just convert it to a string before using the above-mentioned methods.
asg.sm (4 КиБ) скачан 57 раз(а).
#5 Опубликовано: 07.07.2023 23:52:52
Something like this?
z can be anything and come from anywhere.
As long as it has same length with v.
StrAssign.sm (6 КиБ) скачан 47 раз(а).
Click to enlarge
#6 Опубликовано: 08.07.2023 17:48:00
Lupus the Canine
Lupus the Canine
Thank you for your help makraska and overlord.
This look great. I will throw eval in there to be sure it is numeric assignment.
#7 Опубликовано: 10.07.2023 09:53:28
Thanks, unfortunately value to be assigned is supposed to come from somewhere else ...
I was looking for a function that would turn a string into a variable that can be used as operand in assignment.
algo(col) will deal with mixed import matrix.
You can code to convert mixed or numeric or string.
Select the desired matrix-col.
Subsequently, set your maths.
The attached document SS 6179, I checked it opens 30405.
Please, confirm it opens on your system.
Maths Convert-str2num COL algo.sm (5 КиБ) скачан 63 раз(а).
