1 страниц (14 вхождений)
solve 2 equations with 2 variables - solve 2 equations with 2 variables - Сообщения
#1 Опубликовано: 23.08.2017 04:25:38
what is the best way to solve 2 equations with 2 variables?
example:
(Fa*2)+(Fb*10)+20=0
(Fa*3)+(Fb*9)+15=0
What is the easiest way to solve the 2 equations with 2 variables ?
What function can I use best to find the values of Fa & Fb?
Sjoerd
example:
(Fa*2)+(Fb*10)+20=0
(Fa*3)+(Fb*9)+15=0
Sjoerd
#2 Опубликовано: 23.08.2017 07:15:13
There are more ways exemplified in the attached Smath.
Setup the system in traditional format, the solving
algebra follows ... Universal. Same approach will
optimize a data set for polynomial best fit.
Cheers, Jean
Solve [x,y,z] Compactum.sm (91 КиБ) скачан 101 раз(а).
Cheers, Jean
Davide Carpi 23.08.2017 07:19:00
#3 Опубликовано: 23.08.2017 07:31:09
The Solve function from the Maxima Plugin finds symbolic solutions, equations can be non-linear and involve units.
The attached file is taken from the interactive handbook (available in the extension manager).
_Solve.sm (35 КиБ) скачан 244 раз(а).
#4 Опубликовано: 23.08.2017 11:07:04
#5 Опубликовано: 23.08.2017 18:32:45
Many Thanks for the help sofar. I downloaded v14 + maxima en try to use the solve function, but I got the message as displayed in the enclosed file:
Translation of Dutch message: The reference of the object is not adjusted to an item of the object
What can be the problem ?
Another question: the solve option under the Calculation tab is grayed out. It seems I can not use this solve option. What can be the point ??
regards,
Sjoerd
regards,
Sjoerd
#6 Опубликовано: 23.08.2017 19:34:02
WroteMany Thanks for the help sofar. I downloaded v14 + maxima en try to use the solve function, but I got the message as displayed in the enclosed file:
What can be the problem ?![]()
What is v14? I recommend to use the latest nightly build of SMath and Maxima, see http://en.smath.info/forum/yaf_postsm11095_Maxima-Plugin.aspx#post11095.
#7 Опубликовано: 24.08.2017 16:53:03
I use version 14 as is visible in :
I use windows 10 . Can that be the problem.
Do I have to do some installation settings to get maxima running ?
I tested the solve.sm file, when I recalculate the page. Maxima starts up but keeps on calculating for a very very long time, without a solution!
Maxima reagiert nicht!
what can be the problem??
regards,
Sjoerd
regards,
Sjoerd
#8 Опубликовано: 24.08.2017 17:58:24
I can only handle problems with SMath 0.98.6398 and newer (nightly builds), at least if related to the Maxima plugin.
With this new version the configuration of the Maxima plugin is easy (I streamlined the settings dialog and fixed several bugs).
Just follow the instructions on http://en.smath.info/forum/yaf_postst2078_Maxima-Plugin.aspx. There have been reports of successful installation under Win10, however, I rund Win7 and thus rely on third party reports. Let me know if there are problems and also if everything goes well.
#9 Опубликовано: 25.08.2017 08:37:48
Wrotewhat can be the problem??
None of the solving approach is correct.
0.5 sec visit 6179 to solve the patients.
Too big to make an image.
Solve System High accuracy.sm (115 КиБ) скачан 79 раз(а).
#10 Опубликовано: 25.08.2017 08:55:59
#11 Опубликовано: 25.08.2017 12:23:23
... rather, download this one. Last module fails after saving.
Very annoying that it works during construction but not after.
Solve System High accuracy.sm (116 КиБ) скачан 70 раз(а).
#12 Опубликовано: 25.08.2017 16:07:45
#13 Опубликовано: 25.08.2017 17:05:10
The only change I did to the executable was to set the 32 bit flag which is required for the Mathcad user library interface to work (Steamtables and Special math functions libs, userefi plugin). If you don't need this, then replace the executable in the portable distribution by the one in the LINUX version (yes, even if you are under win).
If that doesn't work you can still try the installation procedure described in http://en.smath.info/forum/yaf_postst2078_Maxima-Plugin.aspx. This exclusively uses original installers.
#14 Опубликовано: 25.08.2017 17:08:19
Do you mean: you couldn't download none of the
work sheet I attached ? Strange Smath does not
start. Try to call from the icon in the Smath
main directory.
main directory.
Новые сообщения
Нет новых сообщений
