1 страниц (7 вхождений)
Vectors creation with ranged indices - How to use vectors with subscripts (by typing: [) - Сообщения
#1 Опубликовано: 21.03.2018 10:17:31
Does anyone know how to use vectors with subscripts (by typing: [) in SMAth as I have done in the attached Mathcad file (.pdf + .xmcd). I have tried it in SMath (see the attached SMath file) but this does not work in the same way. Does anyone knows a workaround?
Best regards,
Rens Servais
Файл не найден.Файл не найден.Файл не найден.
Best regards,
Rens Servais
#2 Опубликовано: 21.03.2018 10:54:39
Hello Rens,
You can do it in the same way, but indices here are base 1 instead of base 0
SMath file (r1).sm (4 КиБ) скачан 77 раз(а).
![2018-03-21 14_55_53-SMath Studio - [SMath file (r1).sm_].png](/ru-RU/file/rZcxyq/2018-03-21-14_55_53-SMath-Studio---_SMath-file-_r1__sm___png)
#3 Опубликовано: 22.03.2018 07:12:23
Thanks a lot Davide!
Rens
Rens
#4 Опубликовано: 22.03.2018 11:09:04
Reminded me of a loop I had for Mathcad. Somehow, the equal sign is not correct and not working. A little help? Range2Vec program.smz (2 КиБ) скачан 73 раз(а).
#5 Опубликовано: 22.03.2018 11:20:17
WroteReminded me of a loop I had for Mathcad. Somehow, the equal sign is not correct and not working. A little help? Range2Vec program.smz (2 КиБ) скачан 73 раз(а).
What would be the expected result?
#6 Опубликовано: 22.03.2018 11:26:42
You had Count as subscript instead of index in the loop.
Range2Vec program.smz (2 КиБ) скачан 75 раз(а).
#7 Опубликовано: 22.03.2018 11:26:57
Wrong subscript ... Fixed Range2Vec.smz (3 КиБ) скачан 84 раз(а).
Новые сообщения
Нет новых сообщений
