1 страниц (7 вхождений)
Problem with integral (again) - Definite Integral - Сообщения
#1 Опубликовано: 15.12.2022 12:03:46
Hi!
I have the following code, and the last integral is not solved by the program. I did not find any solution.
Can you explain me, what is the problem?
Thanks a lot!
Bye
Pali
HF.sm (72 КиБ) скачан 78 раз(а).
Thanks a lot!
Bye
Pali
#2 Опубликовано: 15.12.2022 14:31:15
WroteI have the following code, and the last integral is not solved by the program. I did not find any solution.
Can you explain me, what is the problem ?
In some way doctored in red. Setup the integrator scalar wrt 'x'.
HF.sm (84 КиБ) скачан 78 раз(а).
#3 Опубликовано: 15.12.2022 15:01:55
Hi Pali. At this time, you can't use if(..) inside an integral, use cases(...) instead. Also, SMath's integral new version can handle better units.
HF.sm (73 КиБ) скачан 83 раз(а).
#4 Опубликовано: 16.12.2022 06:41:10
Hi Alvaro,
thanks a lot! It works fine. Thank you.
What do you mean: new version of integral?
Pali
Pali
#5 Опубликовано: 16.12.2022 06:42:49
I do not really understand what you did, but thanks for your help as well.
#6 Опубликовано: 16.12.2022 09:37:18
1. recast if/else ► if/otherwise.
2. made ∫ scalar wrt 'x' for local/vectorize
HFshort.sm (23 КиБ) скачан 68 раз(а).
#7 Опубликовано: 16.12.2022 14:49:11
Hi Pali. In the "new" version of the integral it puts the units of the result correctly, while before some corrections had to be made. From "list of changes" here: Defined Integral supports units now.
Davide Carpi 16.12.2022 18:26:00
Новые сообщения
Нет новых сообщений
