Some lines turn into black background when loading in another PC
Some lines turn into black background when loading in another PC - Сообщения
#1 Опубликовано: 30.10.2019 15:18:19
jcuadra
jcuadra
0 сообщений из 12 понравились пользователям.
I'm working on the same file at home and at work. Today when I loaded it at work some lines' background turned black. This is version "0.99.7219.26345"
I've been playing with slightly different versions at home and work because of other bugs.
Has anyone seen this?
#2 Опубликовано: 30.10.2019 18:44:29
CBG
CBG
77 сообщений из 312 понравились пользователям.
Change the background color of each line from black to white.
Carlos
#3 Опубликовано: 30.10.2019 20:06:02
Has anyone seen this ?
That freak is very recent from SS 7219.
Edit menu Select all, background White.
#4 Опубликовано: 31.10.2019 04:17:47
I remember it already happened a long time ago... Can you share the file that loads with different backgrounds?
#5 Опубликовано: 31.10.2019 12:23:27
The problem is not constant from all SS 7219 download.
Neither it appeared from day 1.
It first appeared random, now seems every times.
Can it be caused by Win updates crashing some settings ?
Thanks Davide.
#6 Опубликовано: 31.10.2019 13:13:36
jcuadra
jcuadra
Problem is I have a bunch of expressions highlighted in various colors (e.g. user inputs, results), and they would get lost.
#7 Опубликовано: 31.10.2019 13:19:06
jcuadra
jcuadra
Now I have a conundrum.
Because .7030 has a fatal bug for my application:
https://en.smath.com/forum/yaf_postst17433_bug-with-function-with-programming.aspx
Suggestions?
#8 Опубликовано: 31.10.2019 22:17:25
From the few crappy all black SS 7219 downloaded
from the forum, NONE got lost following the procedure
previously offered. Another way of doing is as simple:
open the document [Work sheet], they are all black,
Edit, Select all, A from menu, select yellow.
You should see all of them yellow on black.
Change background to white, Edit, Select all,
A from menu, change yellow for black.
What we don't know yet: is it Smath or Windows ?
Is SS 7219 not compatible to Win 7 [per say or Win 10] ?
Who cares if you lose decorative inputs/results ?
#9 Опубликовано: 01.11.2019 08:56:27
... download this recently created SS 6179.
What do you get in your recent SS 7219, all black ?
Maths Polygon Area_Perimeter.sm (55 КиБ) скачан 71 раз(а).
#10 Опубликовано: 01.11.2019 12:35:27
jcuadra
jcuadra
Thanks.
The only black area is attached below.
#11 Опубликовано: 01.11.2019 13:03:00
Thanks.
Yes, because I created this way [yellow maths on black background].
BTW: black is not [0,0,0] rather [1,1,1].
Now, if you take a blank work sheet and recompose on your SS 7219
key stroke by key stroke, i.e: not copy/paste any single piece,
then save, then close PC, then re-open PC, Smath, work sheet.
Does it show all maths black ?
We must exhaust this bug before calling the Sky Hoke.
Thanks for reporting ... waiting for more.
#12 Опубликовано: 06.11.2019 14:14:19
That black bug is annoying but easy to manage
between SS 7219 area pasted in SS 6179.
That does solve your home/work switch over.
Bug Black 7219.sm (59 КиБ) скачан 72 раз(а).
#13 Опубликовано: 15.11.2019 11:34:05
Ruben Sidranski
Ruben Sidranski
17 сообщений из 463 понравились пользователям.
I have the same issue (0.99.7251.32800) with the acoustic file on https://en.smath.com/forum/yaf_postsm59725_Summation-of-log-functions.aspx#post59725
#14 Опубликовано: 11.01.2021 12:45:17
Ruben Sidranski
Ruben Sidranski
Bug is still present in Jean's file. Funny thing is this was MY work. His items came were hit or miss. I'm working off of portable version. See file post #3
#15 Опубликовано: 11.01.2021 13:24:51
The bug is solved since the transparent background is no more saved as black, but existing files are still affected because the background color was saved as black (#000000).
Because it is a legit operation to set the background as black it might be excessive to force it as transparent by the program; IMO the fix should be done manually (if you think there are a lot of file affected and is safe to bruteforce replace the backgrounds, a batch script can do the job easily)
#16 Опубликовано: 11.01.2021 13:41:33
This bug started at SS 7610 from recollection, was reported.
Select all from Edit, background white.
