[SS-2302] Smath File Crash
[SS-2302] Smath File Crash - Сообщения
#1 Опубликовано: 04.03.2016 23:48:32
NDTM Amarasekera
NDTM Amarasekera
The following Smath File worked fine under 97.5890. It opens a Excel data file for analysis.
But it crashes under 98.5905.
Why this happens?
#2 Опубликовано: 05.03.2016 08:08:32
The crash is triggered in sum(1)
Even copying the Q matrix in a definition on the canvas the crash still happens.
Issue isolated: crash sum 1.sm (318 КиБ) скачан 66 раз(а).
P.S. try sum(identity(30)) and sum(identity(50)), the second one crashes for me
opened as issue SS-2302
#3 Опубликовано: 05.03.2016 08:59:45
Try this instead
#4 Опубликовано: 05.03.2016 09:07:29
... sorry, forgot to attach the file
crash sum 1.sm (322 КиБ) скачан 59 раз(а).
#5 Опубликовано: 05.03.2016 12:44:48
NDTM Amarasekera
NDTM Amarasekera
The second one crashes for me too
Davide Carpi 05.03.2016 13:38:00
#6 Опубликовано: 05.03.2016 18:33:25
Группа: Super Administrator
Davide Carpi 05.03.2016 21:05:00, NDTM Amarasekera 06.03.2016 09:53:00
#7 Опубликовано: 05.03.2016 20:55:35
Ioan,
You can dedicate a function "VectorMatrixSum(data)"
Unwrap has many more applications, thus interesting.
Under the hood, your combined Sigmas, they first
Unwrap. Matrices don't exist in computing Machinery.
Matrices exist as serialised components.
The "BombCompute Mathcad 11", copy/paste a fair size
matrix [16000000 per say] takes substantial time.
"Warning: the requested operation may take long time".
Can't be more true.
Cppy/paste 16000000 vector: NO warning message... done.
Chers, Jean
#8 Опубликовано: 06.03.2016 09:49:45
NDTM Amarasekera
NDTM Amarasekera
Thank you Andrey.
The problem on Smath file crash is now solved.
Andrey Ivashov 06.03.2016 17:37:00
#9 Опубликовано: 07.03.2016 00:44:24
Thank you Andrey.
"now solved", maybe not so wrt matrix manipulation.
Observe the matrix scale code: M-Min(M)
I found out this built-in code is weak, prone to failure
with incorrect error message " Matrix is not invertible".
There is no matrix inversion involved. Observe the robust
code doing same. Example has low numerical values. At values
in the order of 10^10, module [1] fails.
Utilities Matrix Scale.sm (14 КиБ) скачан 68 раз(а).
Davide Carpi 07.03.2016 09:19:00
