Curve fitting function - Is there a curve fitting function in Smath? - Сообщения
Is there any curve fitting function in Smath?
I mean using the defined points to find the function of these points!
Thanks a lot!
Wrote... for best examination: close Smath ... open a virgin session.
This way, as you will download, both will be resident in same session.
Open include to inspect the content, close back.
Open Test UpDated ... F9 to run
Test Updated contents 5 stand alone fit examples.
If it does not work wrt your Smath version ... bug.
Try it ... report ... Jean
Genfit Algo Include.sm (36 КиБ) скачан 91 раз(а).
Genfit Algo Include Test UpDated.sm (145 КиБ) скачан 84 раз(а).
Hi Jean,
Thanks for your reply!
I tired the .sm file, but it doesn't work well. Meanwhile, the Genfit Algo Include.sm needs rename as GenfitAlgoInclude.sm.
I put the two .sm files in the same location, t
The information of my Smath is Version 0.99
Looking forward to your feedback, thanks!
[attach]42964
Maybe you can deal with Least Squares Fit
Define_a_Variable_Ajust_by_Last_Square.sm (58 КиБ) скачан 119 раз(а).
Ajust_by_Last_Square_Selection.sm (54 КиБ) скачан 87 раз(а).
Carlos
WroteI mean using the defined points to find the function of these points!
Answer is YES
I don't know an embedded function for this.
But you can write your own function.
Lagrange Interpolation Method can be used.
maple() command is not necessary but it simplifies the function.
Giving more points, curve gets more complex.
Here is some examples for your request.
lagrange.sm (26 КиБ) скачан 94 раз(а).
WroteHello
Carlos
Hi Carlos,
This works really fine, thanks for sharing this!
WroteAnswer is YES
Hi, thanks for sharing this, I will try to learn your file!
WroteHello,
Thanks a lot!
Maxima plugin has the Fit() function, see this post
In the interactive handbook, you find it in the Function Index page.
WroteHi, thanks for sharing this, I will try to learn your file!
You are welcome.
My function is direct method, may not be suitable for large data sets.
Razonar's and mkraska's samples are good to investigate too for that purpose.
WroteAnswer is YES
Yes, it is YES.
This version of your application doesn't need maple for get the simplified lagrange polynom.
lagrange.sm (22 КиБ) скачан 89 раз(а).
WroteWroteHi Jean,
Please, attach your raw data set., i.e: not freaked by else.
Two more examples attached.
Genfit Frechet DIFFICULT.sm (128 КиБ) скачан 66 раз(а).
Genfit Kirby_2 [Reduced] Copy.sm (81 КиБ) скачан 67 раз(а).
A fitting session is mostly governed by the model and techniques.
In short: sky is the limit. Some data set can only be fitted by hand.
Plenty are willing in Smath Community.
Take care ... Jean
Hi Jean,
see the stress-strain data, I would say I am really happy about this forum. I got a lot of fit function information from here! Thanks all!
Hi. Three fitting models for your data.
fit_stress_strain.sm (523 КиБ) скачан 97 раз(а).
fit_stress_strain.pdf (635 КиБ) скачан 105 раз(а).
Wow, it's amazing!
Thanks Alvaro!
WroteHi Jean,
I tried the .sm file, but it doesn't work well.
You have detected a bug wrt your SS version, maybe earlier ones ?
Silent Smath Community ?
If you open the governing Conjugate Gradient ... it could be
the symbolic module has not been saved Symbolic, a common bug reported.
By same token, I will delete all previous attachments.
Please, don't hesitate ... Take care ... Jean.
I guess your original raw data is the one from Alvaro ?
Новые сообщения
Нет новых сообщений
