RC6: SMath Studio 0.98.5932 (29 March 2016)
RC6: SMath Studio 0.98.5932 (29 March 2016) - Сообщения
#1 Опубликовано: 29.03.2016 12:57:24
Группа: Super Administrator
SMath Studio 0.98.5932 available
Latest changes (against SMath Studio 0.98.5928)
  • SS-2291: Displaying of large matrices in equation output improved;
  • SS-154: Square brackets is now used for displaying matrices;
  • Multi-threading issue fixed for environments with slow performance when displaying results of calculations;
  • Vectorization functionality now works correctly with user defined procedures;
  • Performance for visualization of large expressions increased;
  • Fixed issue regarding limited number of matrix/vector cells (maximum was at 32765) for SM/SMZ files;
  • Only one action (open/save/calculate) per time allowed;
  • Interface translations updated.
Download
10 пользователям понравился этот пост
Radovan Omorjan 29.03.2016 13:20:00, уни 29.03.2016 16:28:00, Igor Skarine 29.03.2016 17:29:00, ioan92 29.03.2016 13:06:00, NDTM Amarasekera 29.03.2016 23:13:00, Davide Carpi 29.03.2016 18:07:00, sergio 29.03.2016 14:08:00, Mike Kaganski 29.03.2016 19:20:00, Jaan Praks 29.03.2016 15:07:00, Alexander O. Melnik 29.03.2016 13:21:00
#2 Опубликовано: 29.03.2016 12:59:05
FYI: First 0.98 Stable SMath Studio release scheduled on 1-st April (and it is not a joke).
8 пользователям понравился этот пост
frapuano 29.03.2016 17:37:00, ioan92 29.03.2016 13:07:00, Radovan Omorjan 29.03.2016 13:20:00, Alexander O. Melnik 29.03.2016 13:21:00, sergio 29.03.2016 14:08:00, Jaan Praks 29.03.2016 15:08:00, Ernesto 29.03.2016 15:11:00, Davide Carpi 29.03.2016 18:07:00
#3 Опубликовано: 29.03.2016 16:20:57
Alexander O. Melnik
Alexander O. Melnik
127 сообщений из 494 понравились пользователям.
Thank you for all the hard work, Andrey - 0.98 stable is a major leap forward from 0.97.
I very much enjoy the encreased computation and GUI performance.
Here is a peculiarity I have found in the recent release:
If I click on the matrix defining expression there is a lag. There is even larger lag when I position the cursor right after "2" in "2000" and hit backspace. In fact it seems (based on the duration of the lag) that expression is fully recalculated when I hit that backspace button - I would think it is not the intent.
Also the resulting size of the uncompressed .SM file (sreenshot attached) is 141 MB (it might have always been this large for large matricies). When I try to copy/paste the expression from attached workbook to a blank one, the destination SMath hangs and is not responsive for good 5 minutes now.
Overall though, those are minor hiccups for the performance boost we ar getting with the 0.98 SMath Studio. Thank you very much
P.S.: one day we will be able to define & manipulate 5000 x 5000 matricies quickly and with ease
matrixSL.smz (1 МиБ) скачан 86 раз(а).
This happens on Copy / Paste:
Davide Carpi 29.03.2016 18:12:00, Andrey Ivashov 29.03.2016 17:51:00
#4 Опубликовано: 29.03.2016 17:59:30
Yep, there are many things to do. I've just started to work on performance and I see tens of places in code which must be reviewed.
In fact step between 0.97 an 0.98 is a most powerful update we saw in this project.
Another fact is that with all great help from our community I will never stop
Alexander O. Melnik 29.03.2016 18:14:00, Davide Carpi 29.03.2016 18:12:00
#5 Опубликовано: 29.03.2016 18:10:51
Thank you Andrey
I see two small issues here:
- CTRL+DRAG doesn't propagate the settings of the new feature (copy+paste works fine);
- no history steps triggered for resizing the matrix;
Nice :d
Can we have also an update in the SS core documentation?
#6 Опубликовано: 29.03.2016 18:26:10
Alexander O. Melnik
Alexander O. Melnik
This is inspiring :-)
Keep up the great work!!!!
P.S.: I am sure the community will grow in the near future
Davide Carpi 29.03.2016 19:59:00
#7 Опубликовано: 29.03.2016 18:57:55
Davide,
Thank you! Fixed.
Sure, will upload updated documentations after release.
#8 Опубликовано: 29.03.2016 22:11:31
Igor Skarine
Igor Skarine
14 сообщений из 97 понравились пользователям.
Hello Andrey,
Today found strange error with mwround() function.
Seems to be working in 5928.
#9 Опубликовано: 29.03.2016 22:33:25
Mike Kaganski
Mike Kaganski
I haven't Matlab C++ Math Library; however, other functions work similarily. And your example looks strange (eval() inconsistently positioned).
This works for me (using Diag() as mwround() replacement):
Here is the cause of your error:
Seeems that without eval(), the vectorize() treats output from other functions (stack in this case) as scalar (it doesn't see the array here before function evaluation - you didn't pass one explicitly), and thus ultimately simply passes its result (that happens to be vector) to the exponent.
С уважением, Михаил Каганский
#10 Опубликовано: 30.03.2016 01:11:44
Hello Andrey,
Nothing strange. What you construct right Smath concludes right.
Otherwise, you gave many wrong instructions "Can't calculate"
Just watch on what you plug the vectorise operator. You may have
to put some stuff within brackets.
#11 Опубликовано: 30.03.2016 11:08:19
Igor Skarine
Igor Skarine
Sorry, I was tired tonight and posted obviously wrong example.
The actual code that puzzled me was:
1-st disabled instance of hb_fir() was certainly working in 5928 but doesn't work any more in 5932.
2-nd disabled also doesn't work
3-rd disabled doesn't work
4-th enabled works fine.
I found that almost in all cases using mwxxx() routines almost as convenient as vectorisation and far more safe.
I'm going to use vectorise() only for component-wise multiplication and division of vectors, to eliminate bulky "for" loops.
And those multiple eval() everywhere are annoying. It is good idea as well to change stack to Mathcad style.
stack(0,v,0) - doesn't work (Mathcad style). Now you have to use eval(stack(stack(0),v,stack(0))) to be sure.
Igor
#12 Опубликовано: 30.03.2016 11:51:00
Mike Kaganski
Mike Kaganski
f2_remez???
couldn't you please attach the .sm?
#13 Опубликовано: 31.03.2016 08:26:17
1402 сообщений из 1708 понравились пользователям.
You can use units for this:
Davide Carpi 31.03.2016 14:23:00
#14 Опубликовано: 31.03.2016 10:04:04
Davide Carpi 31.03.2016 14:15:00
#15 Опубликовано: 31.03.2016 14:20:00
Interesting; using the same approach:
The Jean solution is elegant too.
But in the end I'd prefer the built-in way; note that the issue is related only to the first element in stack (in augment too) -> imho if the first argument of these functions is a number should be considered like a 1x1 matrix (meaning that the desired output will be a column vector or a row vector; at first glance I don't see drawbacks);
#16 Опубликовано: 16.04.2016 07:28:10
Hello, Alex.
I've made a great progress regarding large matrices in latest nightly build: http://en.smath.info/forum/yaf_postst7466_SMath-Studio-0-98-5950--16-April-2016.aspx - please check it!
