system of equations
system of equations - Сообщения
#1 Опубликовано: 17.01.2020 06:36:24
Ale16595
Ale16595
0 сообщений из 35 понравились пользователям.
Hi everyone, I have a problem with the equation system shown. does not return any results ... where am I wrong?
this is the .sm file sisstema.sm (59 КиБ) скачан 65 раз(а).
#2 Опубликовано: 17.01.2020 08:47:50
You don't use the Solve() function correctly. The second argument is a list of variables (names), not a list of equations. Solve() is a symbolic procedure and doesn't need initial values.
In your case, there are two solutions because the variable V appears only squared.
Solve returns two lists of equations, which can be applied using Assign() for assignment of the solution variables.
Ale16595 17.01.2020 09:03:00, frapuano 17.01.2020 09:48:00, sergio 17.01.2020 11:14:00, NDTM Amarasekera 17.01.2020 13:33:00
