1 страниц (6 вхождений)
Slope Stability Analysis - A basic approach to find cutting points of strips with profile and slip circle - Сообщения
#1 Опубликовано: 16.09.2023 05:01:44
Ref: Example 12.2 (Page 296) - Soil Mechanics : Principles and Practice by G.E. Barnes.
The attached SM file demonstrates how to find cutting points of strips with the slope profile and slip circle.
(for an assumed strip width of 1m. which can be changed if necessary).
Slip_Circle_Barnes-Ex 12.2-TO FORUM.pdf (238 КиБ) скачан 121 раз(а).
Slip_Circle_Barnes-Ex 12.2-TO FORUM.sm (320 КиБ) скачан 104 раз(а).
#3 Опубликовано: 16.09.2023 13:06:16
#4 Опубликовано: 20.09.2023 01:55:02
The complete solution to Slope Stability Analysis of above example.
Analysis is carried out in 2 parts.
1. With one assumed Center of a slip circle to explain steps involved and resulting cordinates of strips etc., and checked with ACAD drawing.
2. Program to find the minimum factor of safety using multiple arrays of centers.
Slip_Circle_Barnes-Ex 12.2-Min FS-R8-CORRECT-FINAL-R4.pdf (334 КиБ) скачан 92 раз(а).
Slip_Circle_Barnes-Ex 12.2-Min FS-R8-CORRECT-FINAL-R4.sm (522 КиБ) скачан 82 раз(а).
Alvaro Diaz Falconi 20.09.2023 13:14:00, Oscar Campo 20.09.2023 06:39:00, ioan92 20.09.2023 08:01:00
#5 Опубликовано: 21.09.2023 07:45:50
Please make the correction as shown ( replace A with -A in page 3).
Even without this correction, the program will run in most cases, but will give
wrong values for AA for some center cordinates.
This correction is an improvement.
Sorry for the inconvenience.
Oscar Campo 21.09.2023 13:47:00
#6 Опубликовано: 28.10.2023 21:32:18
An improved method to my post #5.
I get Wrong Values OR Errors when using the "Findroot()" function for some center cordinates.
This new method mainly uses "root()" function, with few supporting programs.
Slip Circle Intersection Points - TO FORUM.pdf (392 КиБ) скачан 111 раз(а).
Slip Circle Intersection Points - TO FORUM.sm (247 КиБ) скачан 96 раз(а).
Oscar Campo 28.10.2023 22:03:00, Alvaro Diaz Falconi 29.10.2023 03:11:00, sergio 30.10.2023 15:59:00
Новые сообщения
Нет новых сообщений
