1 страниц (5 вхождений)
issue with user defined diff - [not a bug] - Сообщения
#1 Опубликовано: 29.01.2018 16:41:29
Copy this section, paste in 6484 ... turns read.
Don't understand error message ?
Bug 6484.sm (10 КиБ) скачан 87 раз(а).
#2 Опубликовано: 29.01.2018 21:05:52
... not a bug wrt the construction.
Simply, it creates "shadow in the context" past some of the Alvaro coolprop.
It works at top of the work sheet. Whatever: can't understand the error message.
#3 Опубликовано: 30.01.2018 02:34:50
325 сообщений из 2052 понравились и 1 не понравились пользователям.
Wrote... not a bug wrt the construction.
Sorry Jean, I do not quite understand your point. The picture of regions with the error are out of the context. What was the value of object "f" and "g" prior the error messages? The same name "f" can have a variable "f" or a function "f(x)" and they can exist both. Maybe there might be a problem.
#4 Опубликовано: 30.01.2018 10:51:07
WroteSorry Jean, I do not quite understand your point. The picture of regions with the error are out of the context. What was the value of object "f" and "g" prior the error messages? The same name "f" can have a variable "f" or a function "f(x)" and they can exist both. Maybe there might be a problem.
Within the CoolProp context, f & g may have relationship with their respective
f(T,v) Helmholtz free energy equation,
g(T,p) Gibbs free energy equation
It works at top of the work sheet, but not within the context: shadow in the context.
Thanks Radovan.
Maths CoolProp Alvaro.sm (61 КиБ) скачан 86 раз(а).
#5 Опубликовано: 30.01.2018 11:04:41
Ah, now I see it...
seems related to the fact that the diff function is overridden in amid of the worksheet (see Ndiff, Nint collapsed area)... the unapply() function makes anything (even numbers) as functions, must be improved a little
Radovan Omorjan 31.01.2018 02:48:00
Новые сообщения
Нет новых сообщений
