Beta: SMath Studio 0.99.7691 (21 January 2021)
Beta: SMath Studio 0.99.7691 (21 January 2021) - Сообщения
#1 Опубликовано: 20.01.2021 20:49:22
2270 сообщений из 3734 понравились пользователям.
Группа: Super Administrator
Changes introduced in current build 0.99.7691
Улучшения
  • Automatic replacement context menu item added to TextRegion;
  • Search in TextRegion significantly improved;
  • Text Region: Show all characters context menu item added.
Исправления
  • Visible special XML symbols fixed in Text Region;
  • Issues related to work with ordered/unordered lists fixed.
Разное
  • Refactoring.
Download
SMathStudioDesktop.0_99_7691.Mono.tar.gz (1 МиБ) скачан 1198 раз(а).
SMathStudioDesktop.0_99_7691.Setup.msi (2 МиБ) скачан 5602 раз(а).
6 пользователям понравился этот пост
Вячеслав Мезенцев 20.01.2021 21:36:00, sergio 21.01.2021 05:20:00, Denis Nikitin 21.01.2021 07:19:00, IVR 21.01.2021 15:44:00, Igor Skarine 21.01.2021 20:59:00, NDTM Amarasekera 23.01.2021 00:19:00
#2 Опубликовано: 22.01.2021 18:31:43
Ruben Sidranski
Ruben Sidranski
17 сообщений из 463 понравились пользователям.
Problem with areas. The titles disappeared
#3 Опубликовано: 23.01.2021 00:18:01
NDTM Amarasekera
NDTM Amarasekera
Same problem with my SM files too.
#4 Опубликовано: 23.01.2021 14:20:47
They are there, but not visible unless you try to select the titles.
It is same with smath book with quite sometime, maybe related to document mode, it started with build 7666.
Even if you have disabled or never activated it area titles disappeared from me since document mode is released.
It will be fixed soon I guess.
Regards.
#5 Опубликовано: 23.01.2021 21:08:34
True.
overlord 24.01.2021 11:37:00
#6 Опубликовано: 08.02.2021 13:42:33
Ruben Sidranski
Ruben Sidranski
Andrey,
I can no longer specify a "custom page size". I need larger than 11x17 US.
