1 страниц (14 вхождений)
solve & roots with units - Сообщения
#1 Опубликовано: 03.06.2023 08:48:30
#2 Опубликовано: 03.06.2023 15:37:44
WroteI can it solve in Mathcad - see please mcdx and pdf files
I try solve it (heat transfer) in SMath - see sm file
Help please
SMath symbolic solving of integration is not capable as Mathcad.
Thus integrals can't be used with numeric solvers.
However, you can use a little trick to solve them.
Using maple or maxima plugins is the key.
Here is your problem solved with various ways, roots() and Findroot().
solvewithunits.sm (23 КиБ) скачан 70 раз(а).
#3 Опубликовано: 04.06.2023 02:18:41
Hi. The attached have an al_nleqsol wrapper for a Mathcad block with units, that can accept SMath's integrals too.
Kerimov-Cvetkov-Velichko-1-7 - nSol.sm (17 КиБ) скачан 66 раз(а).
#5 Опубликовано: 05.06.2023 00:08:21
Valery Ochkov 05.06.2023 02:23:00
#6 Опубликовано: 05.06.2023 02:24:02
#7 Опубликовано: 05.06.2023 11:08:24
Hello Valery,
In some application(s), you can associate FindRoot with epsilon.
Solve Diophantine Chemical Balance epsilon.sm (106 КиБ) скачан 56 раз(а).
Valery Ochkov 05.06.2023 11:26:00
#8 Опубликовано: 05.06.2023 17:39:04
#9 Опубликовано: 26.06.2023 02:33:01
Please help, why can't find root for this simple equation?
root.sm (20 КиБ) скачан 52 раз(а).
#10 Опубликовано: 26.06.2023 05:54:06
#11 Опубликовано: 26.06.2023 08:45:01
WrotePlease help,
why can't find root for this simple equation ?
roots solves wrt scalar function(s)
In this example, both functions are scalar wrt 'x'.
Try ... roots[(sin(x)-Gamma(x),x,1]
'x not defined' ... Gamma(x) is not scalar wrt 'x'
Few more numerical functions are not scalar
erf(x), erf(x,n) ... erfc(x), erfc(x,n) ...
#12 Опубликовано: 26.06.2023 08:55:02
WroteTry ... roots[(sin(x)-Gamma(x),x,1]
In that case and similar ones,
RootSecant algorithm will spits out 15 decimals, instantaneous.
#13 Опубликовано: 26.06.2023 10:06:59
WroteWrotewhy can't find root for this simple equation?
Because there aren't unknows
Thanks Davide.
Now I put "N" as unknown in the Eq. But it can't be solved either.
root.sm (19 КиБ) скачан 44 раз(а).
#14 Опубликовано: 26.06.2023 10:58:58
You have to play a little with the precision, especially if there are units involved; in this case, seems that 10^-3 mm is a stable target (10^-2 works too, but in some case it returns the guess value, meaning that is "close enough" for the algorithm - you can see in the plot that 0kN to 200kN is in +0.02/-0.02mm range)
![2023-06-26 15_55_45-SMath Solver - [root_r1.sm].png](/ru-RU/file/KcnuBb/2023-06-26-15_55_45-SMath-Solver---_root_r1_sm__png)
root_r1.sm (24 КиБ) скачан 51 раз(а).
netsonicyxf 26.06.2023 12:18:00
Новые сообщения
Нет новых сообщений
