1 страниц (9 вхождений)
Contour Integral Dummy Style - Contour Integral Dummy Style - Сообщения
#1 Опубликовано: 10.12.2018 13:39:00
Can't manage this otherwise than shitting bricks !
Solution is welcomed ... Thanks
Done otherwise to rescue the Document.
Inst_PID Discrete Schema EXAMPLE_6 Failed.sm (36 КиБ) скачан 54 раз(а).
#2 Опубликовано: 10.12.2018 14:15:29
frapuano 10.12.2018 16:55:00
#3 Опубликовано: 10.12.2018 15:55:07
WroteCan't manage this otherwise than shitting bricks !
In order to pass functions as inputs to other functions you need to declare it as such and pass a "dummy" variable. See following.
There is still a problem in that it is not evaluating properly, I believe.
Inst_PID Discrete Schema EXAMPLE_6_Partlyfixed..sm (44 КиБ) скачан 48 раз(а).
#4 Опубликовано: 10.12.2018 20:29:36
fixed
Inst_PID Discrete Schema EXAMPLE_6 - fixed.sm (46 КиБ) скачан 56 раз(а).
![2018-12-11 00_34_33-SMath Studio - [Inst_PID Discrete Schema EXAMPLE_6 - fixed.sm].png](/ru-RU/file/xLgXx6/2018-12-11-00_34_33-SMath-Studio---_Inst_PID-Discrete-Schema-EXAMPLE_6---fixed_sm__png)
P.S. To obtain similar results, change the integration accuracy to something higher than 100
![2018-12-11 00_53_52-SMath Studio - [Inst_PID Discrete Schema EXAMPLE_6 - fixed.sm_].png](/ru-RU/file/pwH7T5/2018-12-11-00_53_52-SMath-Studio---_Inst_PID-Discrete-Schema-EXAMPLE_6---fixed_sm___png)
- removed answer requested for first argument of the last system;
- used f(number_of_arguments) function of function argument (more elegant, point out that the variable name doesn't matter);
Arie 10.12.2018 20:37:00
#5 Опубликовано: 10.12.2018 23:05:36
Wrotefixed
Dumb question maybe, but how do you get the '#' to show up in the H(#) function call?
#6 Опубликовано: 11.12.2018 00:50:47
WroteDumb question maybe, but how do you get the '#' to show up in the H(#) function call?
As simple as that: x(n,X(▄)) ... simply the native dummy argument
big square imitation Alt220 ... try it.
Thanks all you Doctors ! Just refreshing that huge collection
of PID examples, coming soon.
#7 Опубликовано: 11.12.2018 01:04:47
#8 Опубликовано: 11.12.2018 04:44:48
CTRL+K then #
:d
Wrotebig square imitation Alt220
another option, yes
#9 Опубликовано: 13.12.2018 19:02:18
Hi. This is the setup for use inverse laplace transform for numerically evaluate the response for a system in z domain.
pid_controler z.sm (50 КиБ) скачан 60 раз(а).
frapuano 13.12.2018 19:41:00
Новые сообщения
Нет новых сообщений
