Contour Integral Dummy Style
Contour Integral Dummy Style - Contour Integral Dummy Style - Сообщения
#1 Опубликовано: 10.12.2018 13:39:00
Can't manage this otherwise than shitting bricks !
Solution is welcomed ... Thanks
Done otherwise to rescue the Document.
Inst_PID Discrete Schema EXAMPLE_6 Failed.sm (36 КиБ) скачан 54 раз(а).
#2 Опубликовано: 10.12.2018 14:15:29
Fridel Selitsky
Fridel Selitsky
Tiny fix
Inst_PID Discrete Schema EXAMPLE_6.sm (39 КиБ) скачан 59 раз(а).
frapuano 10.12.2018 16:55:00
#3 Опубликовано: 10.12.2018 15:55:07
Arie
Arie
93 сообщений из 285 понравились пользователям.
In order to pass functions as inputs to other functions you need to declare it as such and pass a "dummy" variable. See following.
There is still a problem in that it is not evaluating properly, I believe.
Inst_PID Discrete Schema EXAMPLE_6_Partlyfixed..sm (44 КиБ) скачан 48 раз(а).
#4 Опубликовано: 10.12.2018 20:29:36
fixed
Inst_PID Discrete Schema EXAMPLE_6 - fixed.sm (46 КиБ) скачан 56 раз(а).
2018-12-11 00_34_33-SMath Studio - [Inst_PID Discrete Schema EXAMPLE_6 - fixed.sm].png
  • removed answer requested for first argument of the last system;
  • used f(number_of_arguments) function of function argument (more elegant, point out that the variable name doesn't matter);
P.S. To obtain similar results, change the integration accuracy to something higher than 100
2018-12-11 00_53_52-SMath Studio - [Inst_PID Discrete Schema EXAMPLE_6 - fixed.sm_].png
Arie 10.12.2018 20:37:00
#5 Опубликовано: 10.12.2018 23:05:36
Arie
Arie
fixed
Dumb question maybe, but how do you get the '#' to show up in the H(#) function call?
#6 Опубликовано: 11.12.2018 00:50:47
As simple as that: x(n,X(▄)) ... simply the native dummy argument
big square imitation Alt220 ... try it.
Thanks all you Doctors ! Just refreshing that huge collection
of PID examples, coming soon.
#7 Опубликовано: 11.12.2018 01:04:47
... like this:
#8 Опубликовано: 11.12.2018 04:44:48
CTRL+K then #
:d
another option, yes
#9 Опубликовано: 13.12.2018 19:02:18
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. This is the setup for use inverse laplace transform for numerically evaluate the response for a system in z domain.
pid_controler z.sm (50 КиБ) скачан 60 раз(а).
frapuano 13.12.2018 19:41:00
