1 страниц (14 вхождений)
error in a system of equations - impossible to get or set an item because it does not exist - Сообщения
#1 Опубликовано: 05.11.2019 14:02:37
#2 Опубликовано: 05.11.2019 15:08:12
"roots" does not work with the units. You must adimensionare equations, or you can try the other features present in the plugin (eg "FindRoot" present "Nonlinear solvers" plugin)
#3 Опубликовано: 05.11.2019 15:52:23
#4 Опубликовано: 05.11.2019 23:57:28
WroteI tried another function but it still gives me an error...
It's a huge system, and generally does not accept all initials same.
I would zap units first. This kind of solving should have it be
solved from P & P [Pain & Prestige] as it reflects real project
that does come out of the blue. Even Mathcad Given/Find may fail
or pedal through constrain.
Attach the work sheet ... some source reference as well.
#5 Опубликовано: 06.11.2019 02:25:20
here is the spreadsheet
calcoli.sm (46 КиБ) скачан 54 раз(а).
it is a system of equations derived from the condition of dynamic equilibrium in the stationary curve motion of a bicycle
#7 Опубликовано: 06.11.2019 15:20:34
Wrotehere is the spreadsheet
1. equalities [1,2,3] are consistant 'N'
2. equalities [4,5,6] are inconsistant 'mixed units'
calcoli.sm (52 КиБ) скачан 57 раз(а).
You must make the system consitant before attempting solve.
#8 Опубликовано: 06.11.2019 15:35:50
#9 Опубликовано: 06.11.2019 15:47:31
WroteI tried to use the solve function but it still gives me an error saying that S is not defined
Did you read my reply just before your visit ?
#10 Опубликовано: 06.11.2019 16:20:21
WroteWroteI tried to use the solve function but it still gives me an error saying that S is not defined
sorry, when I wrote, I didn't notice your message
#11 Опубликовано: 10.11.2019 23:11:18
Hi. Try this setup, using al_ library. I don't know if using better guess values can get better results (eqn 3 and 4 don't get good results)
calcoli.sm (50 КиБ) скачан 60 раз(а).
#12 Опубликовано: 11.11.2019 07:37:20
WroteHi. Try this setup, using al_ library. I don't know if using better guess values can get better results (eqn 3 and 4 don't get good results)
Hi, thanks for the reply, but I think I found the error. The system I wrote has two linearly dependent equations, and for this reason it cannot find a solution.
I will have to modify the whole problem.
#13 Опубликовано: 11.11.2019 14:55:47
Hello Alvaro,
The attached CSTR [SS 6179] example is offered differently,
it is initialized from random guesses: success.
Solve al_nleqsolve CSTR.sm (38 КиБ) скачан 71 раз(а).
Alvaro Diaz Falconi 12.11.2019 13:29:00
#14 Опубликовано: 12.11.2019 13:29:59
WroteWroteHi. Try this setup, using al_ library. I don't know if using better guess values can get better results (eqn 3 and 4 don't get good results)
Hello Alvaro,
Hi Jean. Thanks, very interesting.
Новые сообщения
Нет новых сообщений
