1 страниц (3 вхождений)
[Maxima Plugin] least common multiple - least common multiple implementation - Сообщения
#1 Опубликовано: 22.05.2018 06:13:20
Although lcm() works in Maxima... it won't work for me in Smath using Maxima(lcm())
I'm a noob but researched for hours and am non-the-wiser... Any help is much appreciated.
The only result when searching the forum is a Matlab plugin which I couldn't work... plus I'm not sure lcm() is included with that plugin anyway.
https://en.smath.info/forum/yaf_postst1970_Matlab-C-Math-Library.aspx
lcm.sm (2 КиБ) скачан 110 раз(а).
#2 Опубликовано: 22.05.2018 08:58:17
You need to load the "functs" package in Maxima first. Seems that wxMaxima does that on startup. I could also load this package automatically if required.
You can add this locally to your maxima.xml in the plugin directory (search for this file to find the directory).
![2018-05-22 13_54_34-SMath Studio - [lcm.sm_].png](/ru-RU/file/ndYWDE/2018-05-22-13_54_34-SMath-Studio---_lcm_sm___png)
#3 Опубликовано: 23.05.2018 04:31:44
Thank you Mr. Kraska...
I found a Japanese page where others had to load it on their Maxima first as well.
http://web.sfc.keio.ac.jp/~yama/nos/?p=3505
Also this third party Maxima manual tells users to do so as well.
http://www.delorie.com/gnu/docs/maxima/maxima_95.html
Which turned out to actually be the instructions for SMath not Maxima.
Now I suppose I'll need to write a loop in order to use the function with more than two numbers.
Somewhat curious since Maxima has an ezgcd() function which accepts more than two inputs. Anyhow, I will click thanks on your profile Sir.
update: When I click thank on your post an error occurs.
Новые сообщения
Нет новых сообщений
