Mathcad to SMath_function root and solve
Mathcad to SMath_function root and solve - Сообщения
#1 Опубликовано: 26.03.2021 06:59:33
matteo
matteo
can someone help me to copy this mathcad code in a SMath's one?
I have some problems with the solution of Xn
Thank you
#2 Опубликовано: 26.03.2021 10:09:07
matteo
matteo
ok,
thanks
verifica a flessione_prova.sm (43 КиБ) скачан 64 раз(а).
#3 Опубликовано: 26.03.2021 12:52:12
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Thank you
Hi. sigma.c fucntion is defined with an if clause. SMath can't integrate it, but you can use cases():
Now you can integrate:
#4 Опубликовано: 30.03.2021 04:10:19
matteo
matteo
Thanks Alvaro.
I made your correction, using the function cases(), but I have the same problem if I add other terms to fb(xn), for example if I add Ast*sigma sb(eps) and Asc*sigmasb(eps).
How is it possible?
Thanksverifica a flessione_prova2.sm (43 КиБ) скачан 57 раз(а).
#5 Опубликовано: 30.03.2021 06:37:01
fedeghi
fedeghi
25 сообщений из 112 понравились пользователям.
Possibly an odd bracket problem?
Here appears that Smath is making a group of "y+sigma bla bla" as object for the differential operator
So, fb(x) could not be evaluated.
I placed some brackets to clearly separate "y" from what follows in the equation, see picture below.
It appears that with brackets, fb(x) can be evaluated (but I get an error on units).
Maybe some other formula needs to be checked before?
Ciao!
#6 Опубликовано: 30.03.2021 06:54:56
fedeghi
fedeghi
Splitted the equation in three contributions, it appears the the integral is not consistent with other two terms of the sum
I think calculation should work, once you clear the unit issue which is hidden somewhere in other parts of the calculation.
Ciao
#7 Опубликовано: 30.03.2021 08:03:34
I am pretty sure my units mismatch correction is not suitable.
You should have to check this issue by yourself.
But I had managed to solve your function problem.
Rewriting it make function tick again.
verifica a flessione_prova2_rev.sm (45 КиБ) скачан 64 раз(а).
#8 Опубликовано: 03.04.2021 08:06:31
I've had this pending in background so I'll share the solution even here. Aside the initial issues about if() and units, the integral fails when x_n is set as 0, since epsilon is something/0. Therefore solve range must exclude 0 or the function has to handle it.
Happy Easter and take care, anyone.
#9 Опубликовано: 03.04.2021 18:45:13
Thanks Davide ... Your's all too ... Jean
