Roark Mathcad interactive Book - Сообщения
As was wondering if their is any way to open the "Roark’s formulas for Stress and Strain" mathcad handbook?
Roark's Formulas Stresses Strain 6ed Mathcad Handbook (same as the ZIP archive).rar (9 МиБ) скачан 297 раз(а).
Thank you a lot for the fast answer.
WroteI was wondering if there is any way to open the "Roarkâs formulas for Stress and Strain" mathcad handbook?
My answer is NO ... Smath is not a Mathcad clone.
What I have from Mathcad 8 Pro up to Case 12.a
All that stuff are only formulas, but not only formulas.
Each example, thus each eventual application case
are base on the solve bloc Given/Find [linear]
Smath does have such coded solver.
Very many Mathcad Given/Find have been solved in Smath
via its own solver. Best example is Frobenius, Quaternion ...
I see no problem making an Smath Roark, quite a project.
It should be no problem adapting the units ISO [metric].
Put the stuff up to Case 5a in Smath document,
attach in this Forum for eventual collaboration.
WroteSmath does have such coded solver.
Smath does not have ...
WroteAs was wondering if their is any way to open the "Roarkâs formulas for Stress and Strain" mathcad handbook?
It is possible, but you need to convert all mcd files to xmcd format. You can do it manually using Mathcad 11. After that you can try open xmcd files in SMath Studio.
WroteIt is possible, but you need to convert all mcd files to xmcd format. You can do it manually using Mathcad 11. After that you can try open xmcd files in SMath Studio.
That stuff is Mathsoft from Mathsoft, i.e: from Mathcad.
The collab has that stuff, just to be converted Given/Find.
Smath is not going to convert Given/Find.
That bloc is Mathsoft property.
I'm saying that because you are suggesting Smath will run.
I took some time rewriting the roark for Smath,
It is not finished yet, and I am still working on it on my spare time, as it improve both my understanding of smath, and structural calculation.
Many calculations can be done in other way, and if pple find a faster, or more interesting way to solve some equation/problems, i would be really interested, and integrate it.
roark v0.1.7z (1 МиБ) скачан 121 раз(а).
One last question:
My aim is to make an handbook, how can i perform this?
Thankyou,
Pierre
Simply attach your *.sm document to read at opening.
Thanks, Jean.
WroteDear all,
One last question:
Thankyou,
Pierre
The links in your book don't work for me. It seems that batch production of links using the toolbox from the text region utilities plugin don't produce valid links any more.
So you might have to edit the xml file as I had to when I started to create the interactive handbook.
Новые сообщения
Нет новых сообщений
