Stable: SMath Studio 0.98.6128 (11 October 2016)
Stable: SMath Studio 0.98.6128 (11 October 2016) - Сообщения
#1 Опубликовано: 11.10.2016 11:42:14
2270 сообщений из 3734 понравились пользователям.
Группа: Super Administrator
List of changes(between 0.98.5950 and 0.98.6128 versions)
Download
SMathStudioDesktop.0_98_6128.Mono.tar.gz (1 МиБ) скачан 2408 раз(а).
SMathStudioDesktop.0_98_6128.Setup.msi (2 МиБ) скачан 18689 раз(а).
Tutorial
  • SMathPrimer.pdf (Date: 11.11.2011. File size: 2.06MB) - to open in Adobe Acrobat Reader
Other files
SMath Studio icons () of all available sizes (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) in PNG format.
15 пользователям понравился этот пост
Alexander O. Melnik 11.10.2016 12:30:00, Radovan Omorjan 11.10.2016 12:33:00, bdrunagle 11.10.2016 12:35:00, sergio 11.10.2016 12:48:00, Davide Carpi 11.10.2016 13:23:00, NDTM Amarasekera 11.10.2016 13:36:00, Вячеслав Мезенцев 11.10.2016 13:43:00, Arie 11.10.2016 14:17:00, frapuano 11.10.2016 14:33:00, Mike Kaganski 11.10.2016 18:24:00, Василий Николаевич Храмушин 12.10.2016 01:44:00, Serg 12.10.2016 07:04:00, IVR 12.10.2016 12:29:00, Christopher Bietz 13.10.2016 08:11:00, Martin Kraska 17.10.2016 05:58:00
#2 Опубликовано: 11.10.2016 22:51:17
Mike Kaganski
Mike Kaganski
  • [SS-93]: Multiple decimal symbols allowed in variable name now;
Could you please allow both "." and "," to be used and shown as-is in second and following cases in names?
First one, of course, should continue to be converted to "." regardless of which character was used, because otherwise that invisible character (used to create "subscript") may create two different variables that look identically.
But subsequent colons and dots are visible, and thus may be used as is, to avoid different name display depending on current decimal separator, and to enable using intended character (like in Xa,b - here a and b used as list; Xmin.h - here dot is used as separator, and colon would look worse).
С уважением, Михаил Каганский
#3 Опубликовано: 12.10.2016 07:25:07
Please help -- once it is gone - by itself
#4 Опубликовано: 12.10.2016 07:53:56
All three symbols (., should be allowed, as principle; there are some problems though:
- front-end: triggers arguments separators, if the argument separator symbol is allowed as separator in the subscript;
- back-end: drive properly the plain text;
- back-end: localization conversion (I mean, a.b,c with standard settings should be converted to a,b;c when decimal symbol is set to comma and semicolon is used as argument separator);
2nd and 3rd point can be driven using alternative characters that looks like the others ("greek question mark" ; [U+037E] / "single low-9 quotation mark" ‚ [U+201A] / "small full stop"﹒[U+FE52]
for the first point I guess the only way is to use some shortcut key.
o_o
Can you share some info about your system? (Operative System, DPI); it appears always or only in some case (new worksheets, existing worksheets)? a clean install might help?
#5 Опубликовано: 17.10.2016 05:57:48
There is a new bug in the interactive handbook. If you follow a link, then the contents of the new sheet is shifted to the position of the mouse click, as if was pasted at that location.
#6 Опубликовано: 17.10.2016 15:21:09
Yes, I'm working on it.
Thank you!
#7 Опубликовано: 17.10.2016 19:32:55
It seems that "i" still causes some headaches. I used a part of one of my standard files and get this rather strange error message
See please the attached file. I have no idea why the famous "i" variable made a mess here
i_problem.sm (20 КиБ) скачан 125 раз(а).
#8 Опубликовано: 17.10.2016 22:17:40
It does not make mess 5346.
FindRoots [Φ.o] looks under defined wrt Maxima that needs a function
whereas it is not a "root". A "root" crosses the X axis. Φ.o can be
anything in the Catesian plane. You can solve point by point but
NOT on a range. Mathcad 11 would not do either. You are in fact,
in other words, "inversing a function". The Mathcad way is the
"seeded root scanner" over a prescribed discrete range ...
as fast as a lighting strike !!!
Cheers Radovan: Jean
Radovan_2.sm (14 КиБ) скачан 119 раз(а).
Radovan_1.sm (27 КиБ) скачан 118 раз(а).
Radovan Omorjan 18.10.2016 03:42:00
#9 Опубликовано: 17.10.2016 22:56:44
... neither roots(2) and roots(3) work same as in Mathcad 11 and earlier.
The attached is the Smath 5346 "iterative root scanner". It works but
can't be made "seeded". It re-solves from the starting point. Thus
takes several seconds instead of ~ 0 second if it would keep solving
from the last calculated value [seeded to last value].
I bet there is a twist, but just RemToDo.
In some way, I abandoned because of solving the "data set companion"
not possible in Smath whereas it does not have the Mathcad Given/Find
equivalent.
Solve INVERSE Mathematica.sm (9 КиБ) скачан 126 раз(а).
#10 Опубликовано: 18.10.2016 03:53:50
Thank you Jean for your analysis, but I think that here is again introduced some glitch regarding variable i and for loops. I can not figure out what actually happen here, but I could see that there is something that causes that strange error message. Somehow, in the summation instead of variable "i", you get the actual value of i (I do not know why) and it complains because variable can not start with number.
#11 Опубликовано: 18.10.2016 07:27:20
It is not about i, there is a bug in preprocessing wrt the iterator argument of sum() when unknowns are involved in other arguments on definitions; the iterator name is replaced with a value, then when sum tries to evaluate the name is lost.
iterator arg.sm (7 КиБ) скачан 135 раз(а).
Radovan Omorjan 18.10.2016 08:18:00
#12 Опубликовано: 18.10.2016 08:21:57
Thank you Davide
I was quite close to figure this out, but failed. Fortunately, it is not about "i".
Wish you all the best,
Davide Carpi 18.10.2016 13:59:00
#13 Опубликовано: 18.10.2016 17:30:38
CBG
CBG
77 сообщений из 312 понравились пользователям.
Must be not define the variable k, which must be defined is the variable x, because apparently, the sum function does not accept symbolic evaluation
Carlos
iterator arg_CBG.sm (8 КиБ) скачан 116 раз(а).
Radovan Omorjan 19.10.2016 02:27:00
#14 Опубликовано: 18.10.2016 17:52:52
Thank you Davide
Smath 5346 does not suffer the bug that Davide has isolated.
Attached is your project as far as I understand.
Takes 5 min to compute all 35 "Sol" . Works well.
RemToDo: the seeded "solve", I have an idea ?
Cheers, Jean
Forum Radovan_1.sm (40 КиБ) скачан 123 раз(а).
#15 Опубликовано: 19.10.2016 16:36:29
1402 сообщений из 1708 понравились пользователям.
Андрей, я тут "набросал" черновую версию сборки пакета SMath Studio для Ubuntu 16.04. Будет время - займись. Я там напутал с правами немного, на самом деле можно всё без root'а собрать. Потом может быть сделаю видео по-проще. Некоторые утилиты нужно будет скачать из сети (если команда не будет найдена). Это касается создания md5sums файла.
Andrey Ivashov 20.10.2016 05:04:00
