Error by ODEs solution
Error by ODEs solution - Help please - Сообщения
#1 Опубликовано: 14.12.2023 01:35:18
Valery Ochkov
Valery Ochkov
55 сообщений из 633 понравились пользователям.
Here OK Rocket-1.sm (16 КиБ) скачан 48 раз(а).
Here not OK Rocket-2.sm (688 КиБ) скачан 43 раз(а).
About the problem Study-24-How-calculate-Rocket.doc (1 МиБ) скачан 62 раз(а).
from the book
https://www.routledge.com/25-Problems-for-STEM-Education/Ochkov/p/book/9780367345259
#2 Опубликовано: 14.12.2023 09:58:26
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Valery. Just use cases() instead if() clauses.
Rocket-2.sm (688 КиБ) скачан 44 раз(а).
But Newton's second law is not F=ma which is an expression valid only for systems where m is constant. The general expression given by Newton is F=d(mv)/dt or F=dp/dt with p=mv the linear momentum.
Valery Ochkov 14.12.2023 14:13:00
#3 Опубликовано: 14.12.2023 14:30:08
Valery Ochkov
Valery Ochkov
Thanks, Alvaro!
One questions.
How can we solve this problem with ODE as F=dp/dt, not F=m dv/dt?
Will we get others (numerical) answer?
Rocket-2-otherwise.sm (690 КиБ) скачан 51 раз(а).
#4 Опубликовано: 14.12.2023 18:32:10
Alvaro Diaz Falconi
Alvaro Diaz Falconi
The speed of the rocket cannot be independent of the speed at which the propellant exits. Entering that information gives me this solution
Rocket-1.sm (20 КиБ) скачан 47 раз(а).
Another way of looking at it, using the equation F = d(mv)/dt, we must take into account that in a rocket the reaction force is not applied to the same body as the action force, as the 3rd Law says, and therefore the temporal derivative of the product mv must be done by changing the reference frame, which is why it is F = m dv/dt + u dm/dt, where v is the speed of the rocket with respect to the inertial reference system attached to the earth, but u is the speed of the propellant with respect to the non-inertial reference system attached to the rocket
#5 Опубликовано: 14.12.2023 18:35:31
Valery Ochkov
Valery Ochkov
New question
Rocket-1.sm (734 КиБ) скачан 39 раз(а).
#6 Опубликовано: 15.12.2023 01:16:32
Alvaro Diaz Falconi
Alvaro Diaz Falconi
New question...
Hi Valery. You can't take the temporal derivative directly. Please see my previous answer explaining why I think that.
#7 Опубликовано: 15.12.2023 02:39:15
Valery Ochkov
Valery Ochkov
New question...
#8 Опубликовано: 15.12.2023 03:25:33
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Valery. You're right encircling u. Its correct value is u = F/μ. Thus, the force over the rocket is F = - mg - u*dm/dt
Rocket-1.sm (23 КиБ) скачан 45 раз(а).
#9 Опубликовано: 15.12.2023 04:04:15
Valery Ochkov
Valery Ochkov
Thanks, Alvaro.
And what about the 2-stage rocket?
Our first try
Rocket-2.sm (690 КиБ) скачан 51 раз(а).
#10 Опубликовано: 15.12.2023 04:30:05
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Our first try
Hi. Your original solution for rocket-1 is ok, and that implies that the movie's solution is also ok.
I was only pointing out the way to deduce it. Writing the relationship for several stages would imply asking for derivatives for functions with cases(), which cannot be done, because although functions can be integrated with cases() or using inside the Mathcad block, they definitely cannot be derived.
So I guess the best solution is the one you gave at the beginning, simply replacing the if() with cases(). The deduction based on physical principles has already been done for one stage. Now it remains to apply the simplified result for several, which is exactly what the rocket-2 case does.
#11 Опубликовано: 15.12.2023 05:00:55
Valery Ochkov
Valery Ochkov
I think it is easier to solve two equations - for two stages, and then for one (last) stage of the rocket.
#12 Опубликовано: 15.12.2023 06:58:19
Analytical reference solution for h(t) (from a mechanics textbook) and with a single second order DE. in() would be even better without braces (operator form)
Rakete.sm (21 КиБ) скачан 53 раз(а).
Rakete2.sm (21 КиБ) скачан 60 раз(а).
#13 Опубликовано: 16.12.2023 15:47:47
Valery Ochkov
Valery Ochkov
I would like to publish an article about Rockets in the Journal "Physic in school".
Martin, Rasonar!
Would you like to be coauthors?
See please attach
Polet na Lunu.docx (585 КиБ) скачан 48 раз(а).
Rakete-1.sm (16 КиБ) скачан 53 раз(а).
Rakete-2.sm (17 КиБ) скачан 53 раз(а).
Alvaro Diaz Falconi 17.12.2023 02:04:00
#14 Опубликовано: 17.12.2023 02:10:50
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Martin, Rasonar!
See please attach
Hi Valery. Sure. It will be a great experience.
#15 Опубликовано: 17.12.2023 05:05:30
The book about Holistic is the rocket model ... works fine in Smath 30405.
Once data will be collected clean, it may be interesting to collect as a function.
A good candidate may be Thiele.
The rocket system does not follow a single DE law, Like ISA.
Thiele fits ISA form - 1km ... 100 km
Jean.
#16 Опубликовано: 17.12.2023 05:49:57
Martin, Rasonar!
See please attach
Polet na Lunu.docx (510 КиБ) скачан 42 раз(а).
Of course. If I remember correctly, some time there were examples for three-body problems earth-moon-spacecraft. Can't find it just now but that could make another co-author.
Edit: https://en.smath.com/forum/yaf_postsm76986_Mathcad-Toolbox.aspx#post76986
#17 Опубликовано: 17.12.2023 15:12:04
Valery Ochkov
Valery Ochkov
See see please solutions from Slava
three bodies problem
#18 Опубликовано: 17.12.2023 21:42:27
I tried Cholesky ... Quite good.
For this 6 points Rocket from the book, Holistic works fine.
Unfortunately, we don't have an exportable formula.
Re-Conciliate the project ... Thiele
#19 Опубликовано: 17.12.2023 22:33:09
Valery Ochkov
Valery Ochkov
Thanks, Alvaro!
My email OchkovVF@mpei.ru
#20 Опубликовано: 18.12.2023 07:35:01
Alvaro Diaz Falconi
Alvaro Diaz Falconi
3 stages variation.
Checking with Tsiolkovsky rocket equation in a gravitational field with several stages
Rakete-3.sm (46 КиБ) скачан 53 раз(а).
