1 страниц (11 вхождений)
Forum Interface - A lot changed - Сообщения
#1 Опубликовано: 12.04.2025 00:16:50
It seems design of forum is changed tremendously.
Are there anything we should consider for further usage?
Alvaro Diaz Falconi 13.04.2025 21:04:05
#2 Опубликовано: 12.04.2025 02:44:30
Hello.
Hope you are doing well!
You are right, many things changed.
We are just switched to another Forum engine which we have full control on.
All data is moved from previous forum to this one including users, public forums, topics and messages (including history), reactions, reports and private messages.
We made this step to introduce these:
There are many other pros we will have in the future, so this switch was really required.
We still are working to set everything up so some minor issues are possible.
Please let me know if you'll find anything.
Best regards, Andrey Ivashov
- Both English and Russian parts of the Forum now uses SMath user profile, so once you logged in on smath.com you can use the Forum as well.
- Our local AI is now working as a spam filter, so we expect to fix most of spam related issues as soon as AI will be finally set up (it is working in experimental mode currently).
- Private messages are now grouped by subject, so it is much easier to follow up the thread.
- Simplification of using file attachments.
- Moderation page made much more convenient and will be improved further.
- As forum is now a part of our infrastructure we are able to provide more integration (will be available soon): News on the Home Page, comments to the Worksheets in Cloud, chat with Support team etc.
- Fixed issues with unavailable images on Extensions Summary page.
- Reorganize Samples forum into the Worksheets library (further integration with Cloud).
- Restore Russian part of the Forum.
Отредактировано 12.04.2025 09:52:20
sergio 12.04.2025 07:51:02, ioan92 12.04.2025 06:46:39, Rafael H Padilla Velázquez 12.04.2025 17:11:02, Alvaro Diaz Falconi 13.04.2025 21:04:12, Oscar Campo 22.04.2025 16:30:19
#3 Опубликовано: 12.04.2025 14:13:57
Long awaited change, the old panel was a mess. Thank you Andrey!
I still can't delete existing ones or change them positions (^ and X buttons). Also seems that the human readable shortcut can't be set anymore.
WroteAre there anything we should consider for further usage?
On top of my mind, sometimes it was mentioned that the active discussions list seems too short when there are multiple discussions active.
Отредактировано 12.04.2025 15:10:41
francesco rapuano 12.04.2025 16:13:46, Alvaro Diaz Falconi 13.04.2025 21:04:23, Andrey Ivashov 12.04.2025 15:13:58
#4 Опубликовано: 12.04.2025 16:21:19
I used to have a different username between forum and smath.com, I guess this originated due to the fact that I joined the forum on 2014 or similar, but users to handle SMath licenses are in place since 2020 or something.
I guess that I should have used the same user ID of the forum when I created the smath.com user in 2020? Not sure.
Anyway, my previous forum username was named "fedeghi".
The migration to the new forum engine allows me to login in with my (private) SMath account and email address (please note that I also have another company account, since I was able to promote enough the magic of SMath in my company, to the point that 5 business licenses were purchased in 2024.).
If it was possible to merge my old "fedeghi" forum user (posted replies, private messages, etc) with this (apparently new) forum user (related to my private SMath account) from which I'm writing now, it would be good and appreciated.
But if this takes more than a couple of minutes to figure out how to merge users or migrate from "fedeghi" to this user here, than no problem at all: leave it as it is and I'm going to start from scratch using the forum with this fresh user ID. It will be completely fine!
Thanks
fedeghi/federico
Thanks
fedeghi/federico
⚜ Kenny Lemens, P.E. ᵂᴵ 14.04.2025 13:57:26, Alvaro Diaz Falconi 13.04.2025 21:04:32, francesco rapuano 14.04.2025 13:16:18, Andrey Ivashov 12.04.2025 16:36:16
#5 Опубликовано: 12.04.2025 16:34:46
Hello, Federico.
Please confirm the user who wrote this message yours: https://smath.com/ru-RU/forum/topic/mCcmVb#msg125741
Generally, we merged users by e-mails, so in those cases when different emails used we had to preserve both user profiles.
I think we need to introduce some common logic to merge different profiles. I'll discuss this with a team.
Best regards, Andrey Ivashov.
Отредактировано 12.04.2025 16:35:19
#6 Опубликовано: 14.04.2025 06:22:51
WroteHello, Federico.
Hi Andrey, I confirm that I wrote that reply.
It makes sense indeed to use the registered email to sort out user profiles. As I said, if there is a fast and easy way to transfer what was "fedeghi" account to my new "federico" account, fine... otherwise leave it as it is, it will be fine anyway
Ps: apparently this new forum interface doesn't allow to see a "preview" of the reply, before posting it? I liked that feature, especially when multi-quoting answers by other users
#7 Опубликовано: 21.04.2025 17:11:37
bbcode noparse not working.
I was using it to prevent text converting into emojis.
#8 Опубликовано: 22.04.2025 02:30:27
Wrotebbcode noparse not working.
Thank you! I will check it.
#9 Опубликовано: 22.04.2025 11:03:10
Another thing that doesn't works properly is the read status for guests. If you are not logged in, everything is always marked as "new post".
Andrey Ivashov 22.04.2025 11:38:29
#10 Опубликовано: 22.04.2025 11:38:25
Davide, agree. This is an easy one.
#11 Опубликовано: 22.04.2025 11:44:02
Wroteif there is a fast and easy way to transfer what was "fedeghi" account to my new "federico" account, fine... otherwise leave it as it is, it will be fine anyway
We have discussed this with a team and it seems currently it is not something we can do without additional development. The general plan is to allow users to have multiple profiles which can be used separately or together at the same time (in that case it will look like profiles are merged). This is not in our schedule yet, but let's see... plans changing sometimes.
Wrotenew forum interface doesn't allow to see a "preview" of the reply, before posting it? I liked that feature, especially when multi-quoting answers by other users
Hope to restore this functionality soon.
Новые сообщения
Нет новых сообщений
