[SS-4609] No XML start tag open
[SS-4609] No XML start tag open - Missing XML start tag - Сообщения
#1 Опубликовано: 03.10.2019 12:43:28
Ryan Freund
Ryan Freund
19 сообщений из 339 понравились пользователям.
Can anyone help recover this file? It says that there is no XML start tag open. See attached
Thanks in advance!
New Beam Design.sm (191 КиБ) скачан 90 раз(а).
#2 Опубликовано: 03.10.2019 16:02:08
Arie
Arie
93 сообщений из 285 понравились пользователям.
Thanks in advance!
Fixed.
New_Beam_Design_fixed_alyles.sm (200 КиБ) скачан 98 раз(а).
For anyone curious. I ended up fixing an empty tag for this particular area title to have an explicit start and end tag. I don't know enough about the SMath parser to know why this is a problem. I didn't try deleting it.
Problem:
Solution
sergio 04.10.2019 04:04:00, Davide Carpi 04.10.2019 12:11:00
#3 Опубликовано: 03.10.2019 16:36:23
Ryan Freund
Ryan Freund
Thanks Alyles!
#4 Опубликовано: 20.05.2020 12:25:47
eswte
eswte
Problem:
Solution
I had the same problem, how did you find the error? There are so much lines y don't know how to find the error
#5 Опубликовано: 20.05.2020 15:36:49
If you have an editor that supports syntax highlighting for xml is easier, usually you can collapse blocks of code and you can spot where something is wrong. You can try to check yourself using programs such as notepad++ or visual studio code.
