Graph animation - Сообщения
#1 Опубликовано: 05.11.2010 18:39:20
Title: Animation curve fitting using a hinged mechanism.
Author: Fridel Selitsky
Download: Lemniscate_mod.sm.
Radovan Omorjan 06.11.2010 08:53:00, Oscar Campo 08.11.2010 15:05:00, Davide Carpi 01.10.2012 17:58:00
#2 Опубликовано: 06.11.2010 08:54:39
Hello Andrey
Nice example of how to simulate an animation using rfile, wfile and F9.
#3 Опубликовано: 11.04.2011 04:42:50
Chebyshev’s Lambda MechanismLambda mechanism is another four-bar straight line generator. Crank link can rotate 360 degrees while the coupler point moves on coupler curve.
Curve has two characteristic motions. First part is straight line and second part is a quick return curve.
By pressing key F9 the top point of a connecting rod on some site describes a trajectory close to a straight line.
https://smath.com/wiki/GetFile.aspx?File=mechanizm2.rar
#4 Опубликовано: 25.04.2011 01:32:20
Video event capture on the screen.
#5 Опубликовано: 01.05.2011 15:41:18
Teo Jansen walking mechanism
https://smath.com/wiki/GetFile.aspx?File=Walking.rar
#6 Опубликовано: 11.06.2011 11:03:29
Andrey Ivashov 29.08.2011 03:49:00
#7 Опубликовано: 29.08.2011 03:37:04
Klann mechanism1
https://smath.com/wiki/GetFile.aspx?File=Klann.rar
#8 Опубликовано: 29.08.2011 03:48:03
Klann mechanism 2
https://smath.com/wiki/GetFile.aspx?File=Klann2noga.rar
#9 Опубликовано: 05.09.2011 07:51:22
Russian Walking Machines "Vos'minog", developed by
and manufactured in VolgGTU (Volgograd).
Have a four-or six-walking mechanism.
1.four links
https://smath.com/wiki/GetFile.aspx?File=Vosminog.rar
1.four links
#10 Опубликовано: 05.09.2011 07:56:03
2.six links
https://smath.com/wiki/GetFile.aspx?File=Vosminog2.rar
#11 Опубликовано: 19.11.2011 11:08:22
The motion of the figure, consisting of circular arcs
https://smath.com/wiki/GetFile.aspx?File=Kruk.rar
Davide Carpi 01.10.2012 17:57:00
#12 Опубликовано: 20.01.2012 18:29:52
Cannabis Curve
https://smath.com/wiki/GetFile.aspx?File=Cannabis.rar
#13 Опубликовано: 20.01.2012 21:05:52
Animations of Ber7 are amazing, no doubt
There should be a gallery of all these fantastic animations in one dedicated place.
#14 Опубликовано: 03.02.2012 22:06:54
Chrysanthemum curve
https://smath.com/wiki/GetFile.aspx?File=Chrysanthemum.rar
#15 Опубликовано: 03.02.2012 22:08:58
Butterfly Curve
https://smath.com/wiki/GetFile.aspx?File=Butterfly.rar
#16 Опубликовано: 19.02.2012 09:29:54
Sierpinski triangle( Used the program of Uni)
https://smath.com/files/Download/k22b2
https://smath.com/wiki/GetFile.aspx?File=Serpinsky.rar
Davide Carpi 01.10.2012 17:57:00, Andrey Ivashov 19.02.2012 10:35:00, Edward Ulle 19.02.2012 10:45:00
#17 Опубликовано: 24.02.2012 17:21:20
Hi
I've run into this site of a GUI inventor? an thought Ber7 might be interested. It seems to me very inspiring.
http://worrydream.com/
For example, look at the 'kill math' section and the concepts about 'interactive exploration of a dynamical system'
Fridel Selitsky 25.02.2012 00:49:00
#18 Опубликовано: 28.09.2012 10:41:39
Bouncing ball
The algorithm is taken from here:
http://communities.ptc.com/message/188318#188318
https://smath.com/wiki/GetFile.aspx?File=Bounce.rar
Davide Carpi 28.09.2012 11:19:00
#19 Опубликовано: 12.11.2012 00:34:23
Davide Carpi 12.11.2012 07:19:00
#20 Опубликовано: 23.12.2012 16:24:11
Whirls are figures constructed by nesting a sequence of polygons (each having the same number of sides), each slightly smaller and rotated relative to the previous one. The vertices form logarithmic spirals. The problem is taken from the site http://mathworld.wolfram.com/Whirl.html
Wolfram1.smz (3 КиБ) скачан 148 раз(а).
Andrey Ivashov 28.12.2012 13:58:00, Davide Carpi 23.12.2012 19:51:00, Martin Kraska 23.12.2012 20:31:00
Новые сообщения
Нет новых сообщений
