Graph animation
Graph animation - Сообщения
#21 Опубликовано: 30.12.2012 10:06:59
Fridel Selitsky
Fridel Selitsky
Happy.sm (7 КиБ) скачан 169 раз(а).
Andrey Ivashov 03.01.2013 10:00:00, Davide Carpi 30.12.2012 10:12:00
#22 Опубликовано: 16.02.2013 04:24:34
Fridel Selitsky
Fridel Selitsky
optical illusion
The idea is taken from the site
http://www.mapleprimes.com/maplesoftblog/35171-Its-Better-With-Maple
Although the vertical distance between the curves is constant,
it seems that with increasing distance from the axis of Y, they are getting closer.
Animation helps to overcome this optical illusion
Illusion.sm (5 КиБ) скачан 174 раз(а).
Davide Carpi 16.02.2013 07:42:00
#23 Опубликовано: 24.02.2013 12:04:26
Fridel Selitsky
Fridel Selitsky
Rolling disk on a parabola
ParCyc.smz (4 КиБ) скачан 176 раз(а).
Davide Carpi 24.02.2013 14:36:00
#24 Опубликовано: 02.03.2013 01:16:50
Fridel Selitsky
Fridel Selitsky
Bullseye Illusion
The idea is taken from the site:
[url]: http://demonstrations.wolfram.com/BullseyeIllusion/[/url]
Although the white region has the same area as the blue ring, it appears to be larger
Bullseye.smz (2 КиБ) скачан 173 раз(а).
ioan92 28.07.2013 16:27:00, Davide Carpi 02.03.2013 14:23:00
#25 Опубликовано: 28.07.2013 14:41:20
Fridel Selitsky
Fridel Selitsky
Animation examples from the book “Introduction to Statics and Dynamics
by Rudra Pratap, Andy Ruina.Publisher: Cornell University 2009”
http://archive.org/download/ost-engineering-ruinapratap8-21-10/RuinaPratap8-21-10.pdf
Planar motion1.smz (74 КиБ) скачан 168 раз(а).
Davide Carpi 28.07.2013 15:51:00, ioan92 28.07.2013 16:27:00
#26 Опубликовано: 12.09.2013 14:13:27
Fridel Selitsky
Fridel Selitsky
Three Dissections by Leonardo da Vinci
http://demonstrations.wolfram.com/ThreeDissectionsByLeonardoDaVinci/
Leo2.smz (5 КиБ) скачан 111 раз(а).
Martin Kraska 12.09.2013 15:58:00, Davide Carpi 16.09.2013 08:48:00
#27 Опубликовано: 16.09.2013 08:46:53
kilele
kilele
133 сообщений из 397 понравились пользователям.
Challenge for Ber7 :d
This would be a great SMath animation : Heatherwick's Rolling Bridge
See it in action on this video at 1 minute and 25 seconds :
?t=1m25s
Fridel Selitsky 16.09.2013 13:22:00, Davide Carpi 16.09.2013 13:37:00
#28 Опубликовано: 16.09.2013 13:22:27
Fridel Selitsky
Fridel Selitsky
Thank you for the wonderful example .
I'll try to implement it.
#29 Опубликовано: 19.09.2013 00:54:23
Fridel Selitsky
Fridel Selitsky
The Rolling Bridge
Bridge.smz (636 КиБ) скачан 239 раз(а).
Davide Carpi 19.09.2013 00:56:00, Вячеслав Мезенцев 19.09.2013 11:22:00, ioan92 25.09.2013 17:13:00
#30 Опубликовано: 25.09.2013 16:42:16
lrcvs
lrcvs
3 сообщений из 2 понравились пользователям.
Nice, Rolling Bridge!
See you this:
The author
Davide Carpi 25.09.2013 17:52:00, Fridel Selitsky 25.09.2013 18:35:00
#31 Опубликовано: 03.10.2013 03:55:36
Fridel Selitsky
Fridel Selitsky
http://ruina.tam.cornell...k/RuinaPratap8-21-10.pdf
A spring-mass system in space
A spring-mass system consists of two masses, m1 = 10 kg and m2 = 1 kg,
and a weak spring with stiffness k = 1N/m. The spring has zero relaxed
length.The system is in 3-D space where there is no gravity. Track the
motion of the system for the next 20 seconds. Plot the trajectory of
the two masses in space. The 3-D animation showing the trajectory of the
two masses obtained from the numerical solution . From the plot, it seems
like the smaller mass goes around the bigger mass as the bigger mass moves on its trajectory.
springMass4smz.smz (5 КиБ) скачан 134 раз(а).
Davide Carpi 03.10.2013 05:39:00
#32 Опубликовано: 03.10.2013 05:32:30
Brian Runagle
Brian Runagle
13 сообщений из 27 понравились пользователям.
Nice one Ber7!
archive.org had a problem with the link. The book can be found here:
http://ruina.tam.cornell.edu/Book/RuinaPratap8-21-10.pdf
Brian
#33 Опубликовано: 03.10.2013 06:37:02
Fridel Selitsky
Fridel Selitsky
Thank you very much, corrected.
Davide Carpi 03.10.2013 08:13:00
#34 Опубликовано: 21.04.2018 14:34:39
Fridel Selitsky
Fridel Selitsky
Animation of NPlot and 3d Plot graphs
The program is designed for graphs that do not have a built-in
animation capabilities
3dplot mk.sm (8 КиБ) скачан 72 раз(а).
NplotAnimation.sm (14 КиБ) скачан 75 раз(а).
frapuano 23.04.2018 03:02:00
