1 страниц (11 вхождений)
Roots - intersection points - Trouble with finding intersection points of a line and a parabola using "roots" command. - Сообщения
#1 Опубликовано: 14.04.2023 16:43:40
Good afternoon everyone.
I'm using the "roots" command, but I'm not getting the two points where the line intersects the parabola. The command gives me only one result and omits the other point. Attached is the file and image of the problem. How can I find both intersection points?
Roots.sm (8 КиБ) скачан 46 раз(а).
#2 Опубликовано: 14.04.2023 17:35:21
WroteI'm using the "roots" command, but I'm not getting the two points where the line intersects the parabola. The command gives me only one result and omits the other point. Attached is the file and image of the problem. How can I find both intersection points?
As doctored ... Jean
Roots Doctored.sm (9 КиБ) скачан 53 раз(а).
#3 Опубликовано: 14.04.2023 18:41:21
Hi Sergio. There are a 3 argument version of roots, where the third is a guess value for the root.
Roots.sm (9 КиБ) скачан 64 раз(а).
#4 Опубликовано: 15.04.2023 08:54:21
'roots' is essentially based on differentiable function.
Often, in Engineering works you don't have differentiable functions,
Gamma(x), spline fit ... etc.
In those cases, use the X(Φ,a,b,ε) utility.
roots Gamma(x).sm (18 КиБ) скачан 50 раз(а).
#5 Опубликовано: 15.04.2023 19:31:34
Here your solution solved with maple plugin.
No need to enter guess points for this.
Maxima can solve it too, similarly.
PS: MapleCorrect() function can be found here.
Assign() function can be used instead of str2num() + num2str() + strrep().
#6 Опубликовано: 15.04.2023 20:44:04
My personal favourite way to handle solver results is Davide's at() substitution function.
#7 Опубликовано: 16.04.2023 02:49:20
Вячеслав Мезенцев 16.04.2023 03:21:00
#8 Опубликовано: 16.04.2023 09:11:08
Wrote'roots' is essentially based on differentiable function.
Many Smath built-in functions are not differentiable.
diff(▄ ▄) not defined ... Airy example attached.
roots Airy.sm (11 КиБ) скачан 45 раз(а).
#9 Опубликовано: 16.04.2023 11:22:35
WroteHi. This is another way.
What the heck? Can we use maple keywords if they are written as `function`?
This is so mind-blowing, thanks Razonar.
Alvaro Diaz Falconi 17.04.2023 17:27:00
#10 Опубликовано: 16.04.2023 18:34:02
#11 Опубликовано: 17.04.2023 01:44:30
Новые сообщения
Нет новых сообщений
