1 страниц (11 вхождений)
Newton method - Сообщения
#1 Опубликовано: 08.04.2023 16:07:23
I cannot use the roots function and must use one old good simple method by Newton.
What can you say about it?
Newton-Eng.docx (1 МиБ) скачан 89 раз(а).
Martin Kraska 09.04.2023 08:50:00
#2 Опубликовано: 09.04.2023 08:56:19
Very nice.
I had problems when reproducing your 2D version. Depending on initial guess I got errors "requested matrix element does not exist". The situation seemed to improve a little by pre-allocating the vectors X and Y yet it didn't become really robust.
So instead of assigning to j+1 elements I used augment() to add new points to the iteration history.
This is the original version:
Newton2D.sm (21 КиБ) скачан 71 раз(а).
And this is the modified version.
Newton2Da.sm (19 КиБ) скачан 71 раз(а).
#3 Опубликовано: 09.04.2023 14:27:18
Wrote... can't find 2nd root
2nd root confirmed exact.
Solve(f,q,x0,x1,TOL) Copy.sm (162 КиБ) скачан 64 раз(а).
#4 Опубликовано: 09.04.2023 14:33:35
#5 Опубликовано: 09.04.2023 18:19:38
Another way, keeping the mathematical formulation and the iteration algorithm separate. As here.
Newton2Da.sm (13 КиБ) скачан 71 раз(а).
#6 Опубликовано: 10.04.2023 12:25:58
Thanks Alvaro, added to my next Samples visit.
Take care ... Jean
Take care ... Jean
#7 Опубликовано: 10.04.2023 16:21:38
#8 Опубликовано: 10.04.2023 20:29:31
WroteI cannot use the roots function and must use one old good simple method by Newton.
An old vintage in Smath ... two examples.
Take care Valery ... Jean.
Solve_roost f1(x,y). f2(x,y).sm (27 КиБ) скачан 69 раз(а).
#9 Опубликовано: 11.04.2023 14:21:16
Two variations added.
Newton2Da. v2.sm (38 КиБ) скачан 94 раз(а).
Newton2Da. v2.pdf (152 КиБ) скачан 84 раз(а).
sergio 03.05.2023 14:29:00
#10 Опубликовано: 03.05.2023 00:37:31
WroteTwo variations added.
From my future article
Если уравнений не два, а три, то матрица Якоби будет состоять из трёх строк и трёх столбцов. При этом графически отображать решение придётся не двумя кривыми, а тремя поверхностями на 3D-графике, причём их взаимное пересечение и будет отмечать решение (задание читателю).
Слабо!
Alvaro Diaz Falconi 03.05.2023 03:21:00
#11 Опубликовано: 03.05.2023 12:02:25
You may find this Treasury useful/productive.
Solve(f,q,x0,x1,TOL) Copy.sm (300 КиБ) скачан 67 раз(а).
Новые сообщения
Нет новых сообщений
