CSpline interpolation - Сообщения
Thanks in advance.
cspline test.sm (37 КиБ) скачан 122 раз(а).
WroteHi. I have some issues in the attached.
Thanks in advance.
Two red remain ... but here the XY plot.
Cheers, Jean
cspline test.sm (42 КиБ) скачан 105 раз(а).
325 сообщений из 2052 понравились и 1 не понравились пользователям.
WroteHi Jean. Thanks, but you know me ... I want to use my own function.
I messed your coding to make readable.
As it looks, you seem to implement Hermite cubic or an unknown brew ?
Hermite [the Draftsman spline] fits better in certain region,
but is discontinuous at junctions and as such has little interest.
In short, it can be used to create some additional best points
for the next more conventional l_p_c splines, for them now to
be continuous at points, thus analytical up to 2nd order derivative.
Hermite was exhausted in Mathcad, all converted Smath.
If of interest, will be please to attach.
Your original coding did calculate 'V' , but not the freaked code.
Some sort of "shadow in context".
cspline test[NFG].sm (53 КиБ) скачан 94 раз(а).
Spline l_p_c [dspline, fintegrate].sm (78 КиБ) скачан 94 раз(а).
Spline l_p_c [Recovered].sm (129 КиБ) скачан 98 раз(а).
CS only do what mathcad's cspline do:
WroteHi Jean. There are not to much shadow in that small code. It's just the implementation of the traditional spline interpolation. In SMath there are not, or I can't found, the function cspline. The interpolation with cinterp in SMath evaluates the vector V each time that you call it, it's always better to have V=cspline(X,Y) and then call interp(V,X,Y,x). Finally, I want to implement an adaptive step size for the intervals in X. But first I see very convenient to have vectorization and plotting issues solved.
CS only does what Mathcad's cspline does:
1. You have a good point, but invalid: cinterp(X,Y,x) works faster than Mathcad [I tested long time ago].
2. Not supporting vectorization has only one answer to me:
all that stuff is scalar wrt 'x' for the canvas plot only,
but it is NOT a real scalar function like the built-in ones ... sin(x), cos(x), exp(x) ...
3. For the adaptive step size, you may have to invent the wheel or implement
Robert A. [Lagrange quadratic knots ... stricking example attached].
Resume:
1. cinterp => hyperfast
2. Vectorization ... left unsolved
3. adaptive step size => suggested
Thanks Alvaro, most interesting ... Jean
cspline test (1).sm (62 КиБ) скачан 98 раз(а).
Spline Lagrange [Quadratic knots EXPERIMENTAL].sm (47 КиБ) скачан 96 раз(а).
adapt cspline test.sm (83 КиБ) скачан 110 раз(а).
Resume:
I will add this as well, if you do not mind.
Two of the main reasons we want to use interpolation (cinterp f.e.).
I think I mentioned this many times...
4. numerical derivation ... left unsolved
5. numerical integration => solved?
WroteI will add this as well, if you do not mind.
Numerical derivation from the Smath d/dx is not possible ... WHY ?
The derivative operator derives wrt to rules that apply to function(s)
cinterp(X,Y,x) is not a function, only an interpolating function.
Alternately two ways:
1. from the dspline(s,X,Y,t) ... 's' from solving
2. from the infinitesimal D1(x,h,f) ... where 'f' is cinterp(X,Y,x)
Exemplified in the attached ... Jean
Page0 Cubic Copy.sm (104 КиБ) скачан 94 раз(а).
di cspline test.sm (86 КиБ) скачан 128 раз(а).
WroteDerivative and integral for regular cubic splines.
1. Integrator does not recognize p(x)
2. D2(,x) works great.
di cspline test Otherwise.sm (51 КиБ) скачан 98 раз(а).
di cspline test.sm (101 КиБ) скачан 96 раз(а).
1. I don't think you have any kind of spline for real application [added example].
2. From what I tested before Smath cinterp is universal [Matlab, Mathematica, Mathcad ...]
3. Read carefully: Smath ainterp [Akima] is unique to me to Smath.
From previous ad nauseum testing, it fits exceptionally well certain types of data
and is pure crap for other types of data, that's what it is. Superb for the example.
4. On the other hand, integrator supports cinterp, your coding does not.
The cumulative integration does between limits as well, just more greedy in time.
5. I don't understand all that crappy coding from download ... damned mystic !
All in all: most interesting. Thanks Alvaro.
di cspline test [SHORT] Copy.sm (104 КиБ) скачан 108 раз(а).
This worksheet is about adaptive csplines and differentiation and integration of the splines.
cspline.sm (106 КиБ) скачан 119 раз(а).
cspline.pdf (297 КиБ) скачан 104 раз(а).
Новые сообщения
Нет новых сообщений
