Custom Functions plugin
Custom Functions plugin - functions: extended Max and Min, Unit of Measurement, Order of Magnitude - Сообщения
#61 Опубликовано: 13.04.2016 14:13:36
PLUGIN UPDATED SMath Studio 0.97.5346 and later
- SS-2315: cases() doesn't allow creating third row;
- cases(3) used by default instead of cases(1);
#62 Опубликовано: 18.04.2016 20:50:27
PLUGIN UPDATED SMath Studio 0.98.5952 Nightly Build only
Please note: if you have it, update of Custom Glyphs plugin is mandatory to make everything working fine (hidden functions removed, no more interactions between these plugins since this SS version)
- now it is possible to delete placeholders;
- adding placeholders now is "one-by-one" -> will be displayed a non-working cases() when you add or delete a placeholder;
Mike Kaganski 18.04.2016 21:21:00
#63 Опубликовано: 16.05.2016 17:17:54
Alexander O. Melnik
Alexander O. Melnik
127 сообщений из 494 понравились пользователям.
Davide, could you plese update the cases() function to work with units on the RHS? Hugely usefull when integrating piecewise physical properties.
Thank you!
#64 Опубликовано: 16.05.2016 19:24:51
Alex, the 1st condition in your cases() is wrong in both the functions.
You are using 1*'m≤x≤5*'m that bracketed it is (1*'m≤x)≤5*'m; this obviously fails because when you insert 2'm, the result is (1)≤5*'m, hence the "units don't match" error; note that in the 2nd case the error is silent (you will have always 0≤5 or 1≤5).
If you want to have the ternary operator for readability, use lele(...) from the same plugin, that does the job in the right way for you (lele(B,A,C)=(A≤&(B≤C)).
#65 Опубликовано: 16.05.2016 19:50:12
PLUGIN UPDATED SMath Studio 0.98.5973 Nightly Build only
- added image2rgb() / image2rgba();
#66 Опубликовано: 28.05.2016 12:38:55
The function at() seems to have a problem similar to those observed in the maxima plugin.
Davide Carpi 28.05.2016 13:16:00
#67 Опубликовано: 28.05.2016 13:22:02
I prefer the compactum style.
#68 Опубликовано: 29.05.2016 21:31:12
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi. I guess that args for cases must to be unevaluated, like those if statements above. That's not only for errors, also for improve the speed of cases, which seems to eval all options before give the answer.
#69 Опубликовано: 29.05.2016 22:25:49
Mike Kaganski
Mike Kaganski
I suppose you may want to vote for SS-2316.
С уважением, Михаил Каганский
#70 Опубликовано: 30.05.2016 00:12:47
I can't comment wrt your actual version. "cases" does not come with OFFicial 5346,
but is available with the UNofficial 5346. The gorgeous application [made work by
Davide] is the convolution. I tried "cases" in other work sheets and failed.
I toke the plunge to install 5935 ... that killed most of 5346 work sheets.
More nightly build, more incompatibility and less projects working.
Not enough collabs publish working projects.
#71 Опубликовано: 30.05.2016 00:29:02
... there is more to test: as is, 5346 X_Y plot does not support "if/else".
What about plotting some discontinuous from your prefered nightly build ?
#72 Опубликовано: 30.05.2016 00:47:19
Alvaro Diaz Falconi
Alvaro Diaz Falconi
I see: Yep.
#73 Опубликовано: 30.05.2016 05:01:52
Thank you Martin, I'll work on it ASAP.
As mentioned by Mike, this is addressed under SS-2316. As for now to evaluate only the function for the target condition you have to use eval() inside functions or numerical optimization outside functions.
I can't reproduce the first error shown in your picture, what plugin version are you running and in what SMath Studio?
#74 Опубликовано: 30.05.2016 19:05:53
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi Davide. In the attached, with background are all errors "division by zero" cases_error.sm (98 КиБ) скачан 122 раз(а).in version 0.98 b5935 (last stable build, as I understand). Plugin version 1.1.5947.155599
#75 Опубликовано: 31.05.2016 04:51:10
Thank you, I can reproduce. This is before the SS-2318 implementation. In this case, you have to switch the optimization to numeric (symbolic uses the boolean sum and SMath ignores that x is a function's argument). If the function is behind a line, you have to wrap it in a eval().
Alvaro Diaz Falconi 31.05.2016 23:41:00
#76 Опубликовано: 08.06.2016 04:32:11
PLUGIN UPDATED SMath Studio 0.98.5990 Nightly Build only
- fixed at(2) at(3);
- Unknowns now skips the "iterator" argument of diff/int/sum/product functions;
frapuano 08.06.2016 07:43:00, sergio 08.06.2016 04:50:00
#77 Опубликовано: 09.06.2016 17:03:07
Brian Runagle
Brian Runagle
13 сообщений из 27 понравились пользователям.
Hello Davide
Sorry to be thick but I need some help with the cases function.
When I type case( or enter cases from the Insert Function… menu, only two lines are placed on the worksheet:
https://smath.com/wiki/GetFile.aspx?File=forum_attach%2fbdrunagle%2fcases_if_otherwise.png
and I don't know how to add extra if cases.
I've tried dragging corners, as for adding array rows, but with no success. How can I add more cases?
Smath: 0.98.5997
Custom Functions: 1.1.5981.13453
Custom Glyphs: 1.1.5973.13108
Many thanks
Brian
#78 Опубликовано: 09.06.2016 17:10:24
Alvaro Diaz Falconi
Alvaro Diaz Falconi
Hi bdrunagle. Try to write , (or ; if you have this as separator) inside the placeholder of cases. This give you the new extra lines. But be carefull, after inserted, can't be deleted. (Must to copy and paste to new one cases).
#79 Опубликовано: 09.06.2016 17:30:39
Correct
Since some nightly build it is possible (the cost is that you cannot insert a line at once, you have to press the argument separator twice)
#80 Опубликовано: 09.06.2016 17:38:25
Alvaro Diaz Falconi
Alvaro Diaz Falconi
That's seems a very cheap price.
