1 страниц (13 вхождений)
symcs - 🚧 Tiny Symbolic C# Calculator (VS2017, .Net * 2.0, C#) - Сообщения
#1 Опубликовано: 29.06.2014 16:45:23
This is Jasymca for c#.
Source code was automaticaly ported from java to c#. If I'll find some time, we will have another small symbolic engine (maybe embedded in SMath).
not yet available
Links:
1. Jasymca - Java Symbolic Calculator (pdf).
Sources: https://github.com/ViacheslavMezentsev/symbcs
not yet available
Links:
#2 Опубликовано: 29.06.2014 19:56:01
Yahoooo!!
I send my strongest encouragement towards the Siberian wilderness
#3 Опубликовано: 01.07.2014 08:07:58
These two resources may come in handy.
http://sourceforge.net/projects/j2cstranslator/
http://sourceforge.net/projects/ikvm/
I've read that the first one is more for java5.
Good luck, Uni
Good luck, Uni
#4 Опубликовано: 01.07.2014 10:05:02
One more tool to convert java automatically, Sharpen :
http://devtopics.de/2013/06/04/converting-java-code-to-c-code-using-sharpen-to-create-a-sharepoint-solution-part-1/
UPDATED:
New java to csharp converters: http://codecall.net/2014/03/27/best-tools-to-convert-java-to-c-source-code/
UPDATED:
#5 Опубликовано: 11.05.2016 17:09:46
More resources which may be useful to develop this plugin:
http://en.smath.info/forum/yaf_postsm33247_Maxima-Plugin.aspx#post33247
http://en.smath.info/forum/yaf_postsm33260_Maxima-Plugin.aspx#post33260
thanks @Alex.M for reminding me about this thread.
#6 Опубликовано: 05.02.2019 22:18:47
#7 Опубликовано: 08.02.2019 11:14:39
Alvaro Diaz Falconi 08.02.2019 15:18:00
#8 Опубликовано: 08.02.2019 19:05:16
Andrey Ivashov 09.11.2020 20:31:00
#9 Опубликовано: 09.02.2019 00:26:37
Hi uni. Can you upload the compiled file?
#10 Опубликовано: 09.02.2019 09:10:38
Alvaro Diaz Falconi 09.02.2019 12:58:00
#11 Опубликовано: 09.02.2019 18:01:30
WroteWhat's that freak "log"
log is log and ln is ln ... just universal !
As stupid as Mathematica Log for ln
Mupad have log for natural logarithms also. (or Neperian's, even aren't the same). I guess that because the author of jasymca is german, like mupad.
In Uruguay and other spanish speaker countries we also call those logarithms as "hyperbolic", and use uppercase L as symbol for the function.
Just for checking, from the "apuntes de cátedra": https://eva.fing.edu.uy/pluginfile.php/176237/mod_resource/content/1/integrales.pdf
and in all the other classroom material from Universidad de la República: we use log too.
#12 Опубликовано: 15.02.2019 23:37:24
The project has been completely redesigned to support all platforms: .net 2.0, .net core 2.0 and .net standard 2.0.
Compiles but does not work now.
Now some SMath plugins can be more symbolic.
frapuano 16.02.2019 08:20:00
#13 Опубликовано: 17.02.2019 16:37:37
The program is partially restored. It is divided into two parts: the console and the library (Tiny.Science.dll).
This library was the goal of the project. Now its API needs to be brought into a convenient form.
Новые сообщения
Нет новых сообщений
