Polynomial Division Output Issue?
Polynomial Division Output Issue? - Сообщения
#1 Опубликовано: 25.04.2017 16:01:46
Q137
Q137
Greetings!
First post; first use of SMath! Glad to be here...
Found the SMath project while looking about for a modern replacement of my trusty old MathCad. It's quite aged; and I need something I can also use on Linux without resorting to Wine. Need the WYSIWYG man-readable interface; as my life is complicated enough without getting into the pointy-head commandline style of equation entry.
4*s on that critical point for SMath v.0.98
However, what brings me to the forum is best encapsulated with the following screenshot from my Windows machine while running both MCAD and SMath on the same polynomial division problem:
As you can see, MathCad 4 gets it together when calling "simplify"; and SMath, though 24 years newer, seems to miss the point wholeheartedly during the same operation. As a quick threshold criteria, I'm looking for a robust, concise output to ply when challenged with the basic task of polynomial long division.
So here's my question: Are there any plugins/configurations which can make this happen with SMath as expected?
Thanks again; and have a great day!
#2 Опубликовано: 25.04.2017 22:22:39
Sure: the Smath symbolic engine is 'maple' ... not completely coded
but works great for most current needs, example Laplace stuff.
Same as Mathcad: after the maple expression Ctrl+. for the symbolic expansion.
Poly Test.sm (160 КиБ) скачан 76 раз(а).
#3 Опубликовано: 26.04.2017 01:44:09
1402 сообщений из 1708 понравились пользователям.
maple() - just a function from the plugin. SMath Studio has its own symbolic engine.
#4 Опубликовано: 26.04.2017 01:50:17
maple plugin not working for the current build in linux, but it can. Wine must be installed because plugin use it.
[albumimg]1446[/albumimg]
#5 Опубликовано: 26.04.2017 14:00:49
Q137
Q137
Thanks for the feedback; and for the tips --
Have a great day, folks
